BT IP profile stuck at 2Mbps
- Re: BT IP profile stuck at 2Mbps
22-08-2012 7:01 AM
Hello,
Please could someone get BT Wholesale to reset my IP profile? It's been stuck at 2 Mbps for over 3 weeks now. I've tried rebooting and waiting 3-5 days a couple of times but no joy. It has been fine prior to that (about 7Mbps) for around 2 years. I'm syncing at the max speed 8128 and my SNR is around 7.5db and my Plusnet profile is reading 7.15Mbps. It just needs resetting on the BT end. Stats and speed test attached.
It's driving me mad at the moment as I can't stream HD content any more
Message 1 of 8
(1,879 Views)
7 REPLIES 7
22-08-2012 8:03 AM
Quicker to phone or raise a ticket for that, as its pretty much a book a change with BT which any CSA can handle
FTTP 500 regrade from Tues 28th November
Message 2 of 8
(800 Views)
22-08-2012 9:45 AM
Hi Swipe,
I have placed a SNR reset that will adjust your IP profile to match your sync speeds. This normally takes around 4 hours but can sometimes take up-to 24 hours.
Let me know how it goes.
Chris
Chris
Message 3 of 8
(800 Views)
23-08-2012 11:08 AM
Hi Chris,
Thanks for trying the SNR reset but it has been over 24 hours now and unfortunately my BT IP Profile is still stuck at 2Mbps. What would be the next step now?
Swipe
Swipe
Message 4 of 8
(800 Views)
23-08-2012 12:06 PM
Plusnet need to get on to BT and get them to clear a "stuck bRAS profile" (IP profile). Reseting the target SNRM doesn't always cause the bRAS to change.
Message 5 of 8
(800 Views)
23-08-2012 1:37 PM
I have raised this to our suppliers, I am awaiting a response as your profile does appear to be stuck at 2MB/s.
I will have a response from them in the next 24 hours and update you. It should hopefully be resolved by this point.
Chris
Chris
Message 6 of 8
(800 Views)
24-08-2012 11:40 AM
Hi Swipe,
It appears that your profile has now been adjusted. I'd suggest logging into your router clicking disconnect, then power down for a few minutes and power back on. You will then need to login to your router and click connect.
Then test your speeds again.
Let me know how you go.
Chris
Chris
Message 7 of 8
(800 Views)
24-08-2012 4:31 PM
Brilliant Chris. Just done a speed test and it's back at full speed. Thanks very much for your help. Thumbs up for Plusnet!
Message 8 of 8
(800 Views)
