BT Hub 3 or PN 582n?
- BT Hub 3 or PN 582n?
03-04-2013 5:05 PM
I hate to see my 582n router gathering dust and feel like it is good.
Can I ask some fellow guys to reply if they think that the 582n is better than BT hub 3 type B?
Had BT hub since september (bought it off eBay.)
I have had 582n since upgrade to Fibre calls unlimited and was offered a free router. I got this in August.\
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 1 of 8
(1,129 Views)
7 REPLIES 7
Re: BT Hub 3 or PN 582n?
03-04-2013 6:02 PM
100% for the HH3
I had 2 of the 582's (still got one sitting here gathering dust) and the wifi on them was atrocious. (now use a N300 and get a signal all through the house fine)
Message 2 of 8
(592 Views)
03-04-2013 6:30 PM
The wireless performance of the 582n can be tweaked via Telnet commands.
I've tweaked mine earlier today & will report back after a few days.
Message 3 of 8
(592 Views)
03-04-2013 6:52 PM
No you can open it to 40Mhz channels but the performance is still <insert expletive>. In my '50's end terrace it struggled to provide a reasonable signal in the NEXT ROOM ~12 feet away.
Message 4 of 8
(592 Views)
03-04-2013 7:16 PM
Sticking to the HH3!!
Message 5 of 8
(592 Views)
03-04-2013 7:30 PM
HH3a works brilliantly here
Message 6 of 8
(592 Views)
03-04-2013 7:41 PM
Are you on ADSL? - apjashley1
Message 7 of 8
(592 Views)
03-04-2013 7:46 PM
Yes, ADSL2+
Message 8 of 8
(592 Views)
