BT Homehub 3 for fibre
- Re: BT Homehub 3 for fibre
18-07-2013 3:21 PM
Can I use the BT Homehub 3 on it's own for fibre or does it have to be connected to the likes of the dreaded thomson router?.The Homehub has the red BT Infinity socket at the back, that's why I'm wondering. I use the homehub 3 now and it's been great. Was hoping to be able to use it for fibre too.
Message 1 of 6
(876 Views)
5 REPLIES 5
18-07-2013 3:24 PM
Message 2 of 6
(469 Views)
18-07-2013 3:36 PM
Thanks Jim. So I can use the HH 3 on it's own then?....just wanted to double check before the engineer visit. I have been using the HH 3 on Plusnet for about 6 months now and it has been flawless but I didn't want the engineer turning up just to tell me I need extra equipment for fibre.
Message 3 of 6
(469 Views)
18-07-2013 3:46 PM
You still need the Openreach modem, but you won't have to use the Technicolor.
Message 4 of 6
(469 Views)
18-07-2013 4:02 PM
thanks James. Is the Openreach modem supplied by BT when the engineer comes?
Message 5 of 6
(469 Views)
18-07-2013 4:04 PM
Yep. It's part of the install process.
Message 6 of 6
(469 Views)
