BT HomeHub 4 or 5 with Plusnet?
rashm2k
Hi All,
My broadband has switched to plusnet and need an adsl router - wondering if bt homehub 4 or 5 will work with plusnet?
I'm on ADSL not fibre.
thanks!
Fixes: 20
Re: BT HomeHub 4 or 5 with Plusnet?
YES. Check the library.
But basically just factory reset (to remove the FON) and DON'T use a backup to restore the settings from BT.
It just needs your pn username/password entered.
rashm2k
Both Homehub 4 AND 5? I've read about Homehub 5 on the forums but wasn't sure if it only worked for fibre.
[Moderator's note by Dick (Strat):  Full quote of preceding post removed, as per Forum Rule]
Fixes: 20
I've personally used a 2/3/4 & 5 on PN
dnpark38
Quote from: Hairy
I have a 2 and looking at Google I'm informed it can't be used, how did you manage?
http://www.thinkbroadband.com/speedtest/button/1476198475230638155-mini.png
pwatson
dnpark38 - You're on Fibre, not ADSL.
Fixes: 20
I had to flash it with the custom firmware first. Long time ago now though so don't have the info anymore.
If you are on fibre then the HH5 is your best bet.
