BT Home Hub on Plusnet
- BT Home Hub on Plusnet
13-08-2008 10:20 AM
Not sure if this is the correct forum to ask this question but here goes.
I have a friend who is with Bt at present and has the home hub. She want to move to Plusnet at my recommendation and has asked if the home hub will still work.
I have no knowlege of the home hub is it just BT name for the wireless router?
Dave
Dave
Message 1 of 6
(1,488 Views)
5 REPLIES 5
Re: BT Home Hub on Plusnet
13-08-2008 10:36 AM
The BT Home hub will only work with BT Broadband.
Your friend can of course get a free router from PN depending which package she chooses.
Message 2 of 6
(521 Views)
13-08-2008 3:22 PM
James
Thanks for your reply.
Message 3 of 6
(521 Views)
13-08-2008 3:46 PM
I thought you could use the home hub with the right firmware? Or is that a cracked firmware?
Phil
Phil
Message 4 of 6
(521 Views)
13-08-2008 4:07 PM
Apparaently, you can do it by reflashing the firmware with the generic Thomson SpeedTouch 7G firmware (which the hardware is based on).
Not for the faint-hearted, and of course you risk breaking the hub in the process.
As James said, I'd go for the router with the PlusNet package.
Message 5 of 6
(521 Views)
13-08-2008 6:23 PM
I don't think the hub needs to be cracked, just have the latest firmware
see this thread:
http://community.plus.net/forum/index.php/topic,60561.0.html
Jeff
see this thread:
Jeff
Message 6 of 6
(521 Views)
