BT HG 1800
- Re: BT HG 1800
BT HG 1800
02-10-2009 11:00 AM
When I was customer previously,I was sent some fine paperwork to help me set up my wireless.This time,not a thing.Is it possible to have a copy again,as my sister need her computer for other things ?
Message 1 of 9
(1,627 Views)
8 REPLIES 8
Re: BT HG 1800
02-10-2009 11:03 AM
Message 2 of 9
(772 Views)
Re: BT HG 1800
02-10-2009 11:10 AM
It's not as straight foreword as the 'Plusnet pamphlet.
Message 3 of 9
(772 Views)
Re: BT HG 1800
02-10-2009 11:18 AM
What exactly are you trying to do with your wireless?
This bit doesn't help?
http://www.plus.net/support/broadband/hardware/bt1800_setup.shtml#wireless
Message 4 of 9
(772 Views)
Re: BT HG 1800
02-10-2009 11:27 AM
I'm trying to get on line to Plusnet. My broadband went 'live' this morning. In the new house the phone socket is too far from the electric socket,so can't use Ethernet.
Message 5 of 9
(772 Views)
Re: BT HG 1800
02-10-2009 11:30 AM
It's quite possible that your computer won't detect your router until it's been setup properly.
Can you connect your router to your computer via ethernet to set it up? It doesn't have to be connected to your phoneline for you to do that.
Message 6 of 9
(772 Views)
Re: BT HG 1800
02-10-2009 11:31 AM
I'll try later,thanks for helping this old fool.By the way ,where does the Ethernet cable if not into the phone line ?
Message 7 of 9
(772 Views)
Re: BT HG 1800
02-10-2009 12:13 PM
The ethernet goes between the router and the PC.
Message 8 of 9
(772 Views)
Re: BT HG 1800
02-10-2009 2:59 PM
Cheers.As I walked to the shop,the light came on.
I would still like the pamphlet please.
Message 9 of 9
(772 Views)
