BT Engineer Appointment - DSL problem
- Re: BT Engineer Appointment - DSL problem
18-06-2008 12:12 PM
18-06-2008 12:31 PM
If you have tested the internal wiring, filters and router and they're all fine and BT are called out to fix your fault, you would not be charged. You would be charged if any of the above were faulty, but BTs responsibility is from your master socket to the telephone exchange, which they would be obliged to fix free of charge.
18-06-2008 12:38 PM
Quote Could this suggest my friend is wrong and that perhaps it is a router problem?
You'd need to try with another known working router to see if that was the case (it's part of the process you have to go through anyway in order to rule out your hardware).
PlusNet will lend you one as part of the fault resolution process if you can't borrow one from a friend or neighbour.
This guide may be useful as it explains the fault resolution process in some detail.
19-06-2008 3:17 PM
I removed the face plate of the master socket last night, and plugged the router into the hidden socket behind the face plate. The internet and DSL lights come up. I can get connected, but it disconnects after a while. Restarting the router seems to sort it. But I have to do this every so often. Last night it cut out after about 15 minutes, on two occasions.
Apologies for these basic questions, just at the moment I can't afford the ridiculous charge BT might cost me. Even if I had the money, I would be reluctant to give them it!
19-06-2008 3:23 PM
23-06-2008 2:08 PM
I received a notice from PN saying BT have fixed a fault and I should try now. I have tried again, but still I can only get connected for about 10 mins then it drops out. The only way I can get the connection back is by rebooting the router, but again after a few minutes the 'internet' light on my router goes off and the connection is lost.
I have requested some hardware from PN to carry out a test to be sure it's not a hardware problem.
I am very reluctant to give another penny to BT but I require my connection asap and 3 weeks without one is starting to annoy me!
24-06-2008 6:36 AM
I am having exactly the same problem. I even bought a new router without success. Everyone keeps passing the buck but I am the one having to put up with the problem. Have you noticed patterns of when it drops out more? I have found it to be ok in the mornings but struggle with it in the evenings and Friday nights and weekends forget it!
We have now moved on to some sort of time-out somewhere but it's not the router.
I will keep you posted.
24-06-2008 9:45 AM
I borrowed a router from my parents, but I still get the exact same problems I was having before with the DSL light coming on and the internet light coming on for about 5 mins every X hours. I've not noticed any patterns. I'll check tomorrow morning to see if it works fine then, as normally I check around 5:30/6 when I get home from work.
I don't think the problem is my router either. But I am in two minds here:
Do I continue to get great speed broadband for about 15 minutes a week, or do I get BT to take a look at the line and risk losing £140 I can't afford?
I am being told it could it be this that or the next thing which has totally confused me as to what to do next.
24-06-2008 10:00 AM
Can you possibly PM me with a contact number to get hold of you on? I've tried your home number but presumably you're at work.
Looking at your ticket, I think you've been given the run around from your last BT Engineer.
24-06-2008 10:07 AM
From what I can see, we've sent out a router to you which should be with you in the next couple of days. Because we need to eliminate hardware failure (which could prevent you from receiving a hefty BT charge), could you possibly test using this router and let us know how you get on?
If you still encounter the same problems, we'll then be able to get a BT Engineer booked for you.
24-06-2008 10:24 AM
25-06-2008 6:08 AM
I had that dilemma too but after trying 3 computers, 2 routers, 3 filters, changing all my cabling, going through the master socket and still having the problem, I decided to go for the engineer. When he came and asked what the problem was and I explained that the dsl light was on but the internet kept dropping, he tutted, muttering something about the jobs he had to do, connected his computer to the socket, said the adsl was fine and left. I am no better off but I haven't, as yet, received the bill.
I, too am considering just accepting that my home broadband is crap and that anything important will have to be done at work.
Keep me posted on how you get on.
Cheers!
25-06-2008 10:21 AM
Did you see my message earlier in this page?
Quote Can you possibly PM me with a contact number to get hold of you on? I've tried your home number but presumably you're at work.
01-07-2008 10:32 AM
thanks for sending the router, but I am experiencing the same problem. So I have now tested it with 3 routers, on different sockets, with other telecom devices detached, using different microfilters. I have also had a private telephone engineer connect it directly to the line coming into the house.
Still though, the DSL light doesn't coming on, or if it does it's not for long, or flashes on and off.
This might sound silly question, and it may not be valid these days, but I remember ordering broadband about 3 years ago for my old place. We didn't have broadband before, so when placing an order we put our phone number into the ISP's website, which said they would have to activate our line to be capable of broadband.
I don't recall anything like this when signing up with PN, and there has never been broadband in the house I am now in. The previous tennant was using dial up.
I am also worried about the fact that sometimes I can connect for a max of 10/15 minutes but then cutting out. Why am I able to do this?
I really do not want to pay BT a fee!
thanks
01-07-2008 10:35 AM
It shouldn't be anything like that. You supply us with your post code and telephone number and we ask BT to activate your service at that address.
You wouldn't be charged by BT to do any work as a result of an engineers visit if all of your hardware and internal wiring is up to scratch, so given what you've told us so far, I wouldn't expect any charges to be raised.
