BT Business Hub (2700HGV) and long phone lines
- BT Business Hub (2700HGV) and long phone lines
- « Previous
- 1
- 2
- Next »
Re: BT Business Hub (2700HGV) and long phone lines
21-04-2009 7:08 AM
In the meantime, I've applied to Plusnet to have my target SNRM reduced from 12 to 9, then I can reevaluate the 2700HGV. The lowest SNRM I've been able to hang on to is one that stays at around 6-6.25 thru the day, and drops to 5'ish in the evening, so 9 ought to be fine.
21-04-2009 9:02 AM
29-04-2009 6:37 AM
I've now tried it on a more level playing field with the SNRM-adjustable routers - I've had my target SNRM dropped by Plusnet to 9. At this level, the HGV does not achieve as high a sync rate as the best of the rest, but maintains its performance in a smoother way than many. Its in-use SNRM doesn't fluctuate as much as many of the others - on routerstats its almost completely a smooth line, with just a few small dips between 22:00 and 05:00.
It also has something I've not encountered on the other DMT-monitorable routers I've tried - dynamic control of the marking/unmarking of 'tones' found to be unusable. Other routers seem to need a resync/reboot in order to free-up tones once they're noted as being unusable. This feature should enable the HGV to be left running for long periods without resyncs etc.
Its now back into my top 3 for my long-line, high attenuation line, together with the DG834G V4 and the ST585 V6
29-04-2009 12:31 PM
The 2700HGv may seem a more smooth line because it's SNRM is only displayed in whole numbers.
All other routers i have encountered display to one decimal place.
Saying that it is a very good router on long noisey lines.
Ian
29-04-2009 4:37 PM
It might be worth doing a few more tests.
Don't forget the tip when swapping, to powerdown the modem/router and wait a while before disconnecting the line.
02-05-2009 11:37 AM
02-05-2009 2:58 PM
02-05-2009 4:28 PM
02-05-2009 4:34 PM
27-04-2010 3:49 PM
Quote zyxel P-660HW-T1 Because it seems to operate at SNRM 6, I'm beginning to wonder if the modem is set to operate at a pre-defined offset.
can confirm that the post office supplied zyxel P-660HW-T1 v3 ive got on this 63+db line syncs with a fixed 6db NM, where my dg834 v4 syncs to what the DLM says is right NM and even with a snr tweak right down to 6db and beyound on the dg834 v4 it still syncs a good 250-500kbps less than the zyxel and finds it very hard to hold on to the sync.
- « Previous
- 1
- 2
- Next »
