BRAS Profile not updating when sync speed improved
- BRAS Profile not updating when sync speed improved
11-10-2007 11:24 AM
However, despite continually synching at 8128kbps, my BRAS profile seems to not want to increase to what I would expect, instead remaining stuck at 6500kbps.
The new synch speed has been active since the early hours of Monday, so the 'up to 3 days' period that would normally see the BRAS profile adapt has elapsed.
Should I report this as a support question for investigation?
Re: BRAS Profile not updating when sync speed improved
11-10-2007 11:31 AM
According to BT, at 09/10/2007 00:30:21, there was a resync event of 7392Kbps.
If you hold onto 8128Kbps for the next three days, then your profile should increase.
11-10-2007 10:06 PM
Not sure how to post the image, but if you'd like it as evidence I'll happily add it.
11-10-2007 10:11 PM
All you can do is hope it does not happen again (whether it actually did or not) within the next 5 days.
27-10-2007 10:51 AM
However, my profile has not shifted from 7000kbps, meaning I assume that BT still think there are intermitent resync events at slower speeds than the 8128kbps I see all the time on my monitoring software!
Any ideas what I can do, as I'm starting to get frustrated..........I've heard of stuck BRAS profiles, but really do want to know why my profile hasn't lifted, as if there is something happening at the same time each day, I will try and do something to get to the bottom of it!
27-10-2007 6:05 PM
Have I missed something - have Plusnet changed the way they display the data on the Member Centre??????
Something somewhere is not consistent.......the BR Speedtest reports a profile of 7150kbps for my connection, which tallies with what you say.
27-10-2007 7:55 PM
Your High-speed Broadband Service
Your current broadband speed is 8000 Kbps
27-10-2007 8:02 PM
PN do set the high speed broadband figure to 8000 sometimes when they move you to ADSL Max expecting it to be reset to the correct figure after the trial period. However there have been a number of people (non-LLU) saying something similar so it looks like PN have not been processing Bras profiles on some connections.
This will have applied to petejigsaw originally as well and as PJ has indicated, this is not the correct setting for a Max connection and as also stated it is never above 7000. There will also be no difference between a 7000 and 8000 setting as the protocol overheads account for the different when syncing at 8128Kbs.
28-10-2007 8:58 AM
I can confirm however that when I moved in August, I moved within the same town and am still on the same exchange, which does not have any LLU services, so the network infrastructure powering my connection remains unchanged.
My real issue is that despite what you say about 7150kbps being the throughput profile on my connection, speedtests from ThinkBroadband (I have used this consistently since before ADSL Max arrived, and logged all results) increased at my previous address to get well over 6200kbps downstream speeds even at peak times, yet now, with nothing having changed (sync speeds and, if you're right, throughput profile the same) I can not achieve above 5800kbps at off-peak times!
That to me indicates that there is something throttling my connection, or that the exhange is starting to get congested, though none of the stats for it (Tavistock) point towards this, and even if it was, off-peak speeds should have remained constant.
28-10-2007 9:11 AM
28-10-2007 9:43 AM
28-10-2007 9:59 AM
I work a kilometre away from the main Sheffield exchange but a test clocks 3.5 kilometre hence my 1.3Mb connection
28-10-2007 10:07 AM
28-10-2007 10:23 AM
28-10-2007 12:11 PM
I used to sync at 8128 and since about march i've not managed above 5500.
All it takes, I guess, is for openreach or someone to be working on your neighbours line and move one of the connections on yours. It's pants for me as there is no way to get it sorted.
Sorry to be cynical but enjoy the speed while you can. I had mine for 6months to a year before it died.
A
