BRAS Profile Stuck?
- BRAS Profile Stuck?
BRAS Profile Stuck?
25-02-2011 4:33 PM
Looking at the forums it seems that this single issue causes at least half of the BT support work...
Anyway, I had to move the router Sunday during the day, and I think the connection was not very good (the dial tone sounded a bit fuzzy there). I moved it back in the evening. Come Monday morning, the internet is slow as molasses. And it has been ever since. I raised a support request, but so far nothing has happened, apart from a line test. Still slow as molasses.
The download speed is consistently 70kbytes/s, when it used to be about 220kbytes/s. So I checked the available documentation (which is very very very inconsistent), and it seems that the BRAS profile is stuck at 0.75 mb/s, when it should be 2 mb/s. Sync speed is ca 2500 kbit/s, and has been since Sunday evening, to the best of my knowledge. I did switch the router off a few times on Monday and maybe Tuesday, and the reconnect speed is stable.
So, is there anything I can do? Does it help to switch the router on and off, or is that bad? (As I said, the documentation is completely and utterly inconsistent, especially in this point.) Is there anything else I can do?
Message 1 of 4
(716 Views)
3 REPLIES 3
Re: BRAS Profile Stuck?
25-02-2011 4:59 PM
HI MrPuddington,
I've just performed so diagnostics and maintenance which I think may have resolved it. This should take effect in the next fifteen minutes or so.
Jojo
Jojo
Message 2 of 4
(450 Views)
25-02-2011 5:02 PM
Thanks, that worked! The modem reconnected, and the speed is back to normal. Next time I will come straight here instead of going through the "have you tried switching it off and on again?" support channel...
jim:quote
jim:quote
Message 3 of 4
(450 Views)
25-02-2011 5:20 PM
Glad to hear
Message 4 of 4
(450 Views)
