BBYW Pro Speed Problem - please help
domingopuss
I've just receivced an email to say that I have exceeded my d/l limit, which is fine as my month's usage usually resets on the third of every month.  However, yesterday I cancelled my account as I am soon to be emigrating. I basically paid up until 10/10/08 for tyhe Internet access to continue for just over another month.  However, the email says that my speed won't return to normal until 11/10/08, which is the day after my account will be cancelled.
Can anyone help please?
Thanks!
dom.
3 REPLIES 3
Mark
Re: BBYW Pro Speed Problem - please help
I'll take a look at this when I get in and see what we can do to sort it for you.
James
I think the easiest way to fix this will be to remove the scheduled cancellation, which will remove the data transfer watch.
If you let me know a week before you're due to cancel, I can then reapply the cancellation for you, and then we can take any necessary payments at that stage?
Let me know.
domingopuss
Quote from: Jameseh
Let me know.
My speed seems to be back to normal now? and a reply to a ticket I raised has asked for my usage to be reset.
So, I only need to give a weeks notice to cancel?
