BBC iPlayer help
- BBC iPlayer help
BBC iPlayer help
03-08-2007 8:22 PM
thanks
Re: BBC iPlayer help
05-08-2007 2:10 PM
I think it depends on the show you are downloading. I've had very mixed results with it, some downloads have been 400+KB/s some under 50KB/s. I think it's because there's only a limited number of people on the trial and some shows have less people downloading them Checking the ones that were slow for me I was only downloading from the BBC themselves. It was only when I was downloading from other people as well that it would speed up.
I can only suggest keep going and hopefully someone else will start uploading to you in time or pick another show.
Plusnet Technology
06-08-2007 3:59 PM
06-08-2007 4:10 PM
I didn't get any problems myself, it came down very fast. Was anyone else using the connection at the same time?
Other than that, is the web generally fairly snappy? Tried a speedtest at http://www.mybroadbandspeed.co.uk
If all looks well otherwise, then we can only assume that the Beeb network / servers are busy.
06-08-2007 5:36 PM
06-08-2007 5:57 PM
Not really had a chance to have a good play with this yet. Will give it a go soon methinks!
06-08-2007 6:07 PM
Quote from: Liam I
My general speeds are very good, pretty consistent, only to occassional drop in connection or speed...
alls well anyway
06-08-2007 6:16 PM
07-08-2007 9:31 AM
Can someone tell me how to monitor what is happening with the p2p app?
When you start a download a small window appears which tells you how many peers you are connected to. This has a hide button - how do you then get it back?
How do I tell how many people are connecting to me?
The installation says nothing about extra steps if you are using a router. Do I need to set up port forwarding (I have uPnP off)?
07-08-2007 5:50 PM
Plusnet Technology
11-08-2007 11:51 AM
Quote from: jelv The installation says nothing about extra steps if you are using a router. Do I need to set up port forwarding (I have uPnP off)?
You need to forward port 1948. I had thought 1947 also but I can't see it in my router logs so may be mistaken. Mind you, if you don't forward them then the downloads still work, but the uploads don't. Given that you have no control over the uploads you might see that as a benefit....
Updated: corrected ports
