BB speed less than dial up - no reporting method?
chrisaplus
My speed last night was a usual 5mbs down 0.9 up.. this morning it is so slow I can not complete a Speedtest check (reports around 0.2mbs down, test times out).
Yes I have done all the usual checks reboots etc - no nothing makes any difference.  Phone line tone is fine, router reports 7mbs down 1mbs up (lies!).
The only way I can report this seems to be to hang on the phone for 30mins +, as there is no working chat help, and seems there's no way to raise a ticket.
meh  Sad
sisterray
Re: BB speed less than dial up - no reporting method?
Same here.
I am getting 3 Mbps down load - should be getting between 60 and 70 Mbps
My upload speed is fine about 17Mbps.
So I don't think is is my router.
30mins queue on support, no chat available. Support status says no issues with broadband reported.
They mention a way of raising an online support call , but I cannot find it on the site. Can anyone provide a link.
Can someone from Plusnet support investigate
Gel
Seasoned Pro
Fixes: 12
Fixes: 382
Hi there.
I've made some changes to your line settings which should help.
Can you let us know if you see an improvement within 24 hours?
@sisterray
Line tests aren't finding any issues, your router is in sync at 76mbps
How are things since the weekend?
sisterray
It all started working again later on Saturday. I don't think it was my line, as there were a lot of reports from across the country about broadband speed on Saturday
Fixes: 382
Yeah that's what I suspected.
Happy to hear it's back to normal now.
