BB Speed issues and Service Drop outs at night.
- BB Speed issues and Service Drop outs at night.
20-11-2012 2:42 PM
Router info. below:-
Link Information
Uptime:
0 days, 5:38:35
DSL Type:
G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]:
1,168 / 16,468
443 / 16,664
Data Transferred (Sent/Received) [MB/MB]:
7.95 / 99.37
Output Power (Up/Down) [dBm]:
12.5 / 20.0
Line Attenuation (Up/Down) [dB]:
15.0 / 28.0
SN Margin (Up/Down) [dB]:
28.0 / 5.5
Vendor ID (Local/Remote):
TMMB / IFTN
oss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
Error Seconds (Local/Remote):
28 / 0
FEC Errors (Up/Down):
45,536 / 0
CRC Errors (Up/Down):
1,281 / 1,411
HEC Errors (Up/Down):
7 / NA
I've attached the speed test results and there seems to be a real drop off in speed since I changed over to Plusnet. BT are promising all sorts of wonderous speeds if I change back to them and I get a few months free thrown in.
Upload is particularly slow when I'm trying to upload photos etc to Flickr for example.
Re: BB Speed issues and Service Drop outs at night.
20-11-2012 2:49 PM
You also need to ask Plusnet to uncap your upload speed.
20-11-2012 2:54 PM
20-11-2012 3:01 PM
What tells you that my upload speed is capped? and what speed should I get if it's uncapped?
Thanks but I'm a beginner at the BB technicalities.
Thanks in advance.
20-11-2012 3:08 PM
Did you look to see what https://portal.plus.net/my.html?action=stable_rate said?
20-11-2012 3:18 PM
Just says "Estimated line speed:Not recorded (service activated before we introduced estimates).Current line speed: 14.2 Mb" So I'm non the wiser
Certainly not getting 14.2 MB
I've got yo go out now but will be home later tonight so excuse if I don't reply quickly.
Regards.
20-11-2012 3:32 PM
Another thing to try: go in to the router and somewhere there is an option to disconnect. Do that and leave it for around 20 seconds and then reconnect (don't reboot as that drops sync with the exchange, disconnect/reconnect doesn't). Only try this once if it doesn't do anything first time another go won't help.
20-11-2012 3:54 PM
I've checked your connection and it is running at the correct speed your connection has also been very stable. As jelv mentioned are you connected wired or wireless?
I've also placed an order to uncap your upload speed as it makes sense too.
21-11-2012 5:28 PM
Thanks for checks. At the moment I'm running a wireless connection from a desktop PC but I'll fire up the wife's laptop and connect to the router via RJ45 lead and will then post the results here.
Regards.
21-11-2012 11:13 PM
Don't know what to think now. Laptop has no provision for an RJ45 connection, it's wireless only. Anyway sat very close to the router ::), so a great signal and ran the BT test got 12.2 down and 0.980 up so that looked a bit better but still nothing to get too excited about. Came back to the desktop PC as per last night and ran the BT tests again - not great 11.2 down and 0.30 up. Upload speed seems to be worse now
As a matter of interest I've attached a graph which shows the deterioation of the connection speeds on this PC over a couple of years. OK OK I know it's not the official BT test but forget the actual speeds just look at the deterioration.
So I'm not too happy, think I'll try a couple of TP Link devices to link the PC to the router and see if that makes any difference.
Regards,
PS How long does it take for the upload cap to come off?
21-11-2012 11:18 PM
Quote from: Wingco39 Laptop has no provision for an RJ45 connection, it's wireless only.
Unusual. I have seen laptops that appear to be like that but the connection was underneath a hinged plastic cover.
22-11-2012 12:28 AM
22-11-2012 8:13 AM
Quote from: Wingco39 There appears to be one connection on the side of the laptop for a dial-up modem. See Device Mgr pic attached - not sure what the M/Soft miniport adapter is though?
Mo mention of modems in Device Manager. Or non-wifi network adaptors. Bit of a mystery. What is the laptop make and model?
22-11-2012 5:57 PM
It's an Advent Quantum Q200.
22-11-2012 9:16 PM
http://documents.knowhow.com/Computing/AdventQuantum200IconGuide.pdf
Might be worth downloading the drivers and seeing if it recognises the port and also check that it is not disabled in the BIOS
http://www.adventcomputers.co.uk/product-download-select/228
