B T Speed Tester
- B T Speed Tester
B T Speed Tester
28-01-2015 4:06 PM
Results Image not loaded
1. Best Effort Test:
Download Speed : 1.17 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Why am I enable to run the second part of the BT speed tester
Re: B T Speed Tester
28-01-2015 4:25 PM
Quote from: stathe FAQ
Why am I unable to run the second part of the BT speed tester
If we are talking about the same tester the java applet for that is incredibly unreliable.
Try instead using speedtest.net and see what results you get from that.
28-01-2015 4:40 PM
29-01-2015 9:49 AM
Quote from: stathe Please re-run the test if you require this additional information.
How many times have you tried to re-run the test?
Also, what is your exchange capable of... dslchecker.bt.com/adsl/
29-01-2015 10:08 AM
On the few basic checks I've done, the speed test you achieved is about right for your line.
29-01-2015 2:16 PM
Download Speed : 0.97 Mbps
It is that test and this is what I get B T wholsale I would like the rest to work
29-01-2015 4:15 PM
29-01-2015 4:18 PM
30-01-2015 2:41 PM
30-01-2015 3:38 PM
It's don't think it's in Plusnet's remit for this as it's a none service affecting.
I know from past experience that tester is horribly unreliable and as has been said in previous posts if you've ran the test too many times the site will block you from running it.
30-01-2015 5:33 PM
30-01-2015 5:38 PM
Quote from: markg14045
You may be right, but am I right in thinking that Plusnet can see the results of the test their end? So it's useful that way as it's direct evidence of a user experience e for them to see
30-01-2015 5:44 PM
