B.B. very slow loading pages laptop and desktop and youtube buffers
glesgajohn
Hi I am and have been having probs again with my B.B. i have done speed tests on desktop and laptop
my speed returns
DWNLD 6.28---UPLOAD=0.36----PING= 63.00
Iwas  having dissconection probs and the plusnet guy turned speed down since then I can not browse the net at any reliable speed ( pages dont load ) and my youview box buffers when waching IPlayers , it even buffers on YOUTUBE.
can someone please check my line B.B. supply and check to find the fault
cheers
ALSO enclosed SUMMERY from statistics xdsl
thanx
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Link Power State: L0
  Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (1 dB): 5.9 29.3
Attenuation (1 dB): 39.0 24.0
Output Power (1 dBm): 0.0 12.6
Attainable Rate (Kbps): 8528 1120
  Path 0   Path 1
  Downstream Upstream Downstream Upstream
Rate (Kbps): 8502 445 0 0
MSGc (# of bytes in overhead channel message): 61 69 0 0
B (# of bytes in Mux Data Frame): 254 13 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 1 1 0 0
R (# of check bytes in FEC Data Frame): 0 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.9559 0.9333 0.0 0.0
L (# of bits in PMD Data Frame): 2134 120 0 0
D (interleaver depth): 1 1 0 0
Delay (msec): 0 0 0.0 0.0
INP (DMT symbol): 0.00 0.00 0.0 0.0
Super Frames: 0 0 0 0
Super Frame Errors: 5601 244 0 0
RS Words: 0 1383354 0 0
RS Correctable Errors: 0 0 0 0
RS Uncorrectable Errors: 0 0 0 0
HEC Errors: 28632 90 0 0
OCD Errors: 667 0 0 0
LCD Errors: 667 0 0 0
Total Cells: 1679961568 987442872 0 0
Data Cells: 519145734 46981274 0 0
Bit Errors: 0 9071 0 0
Total ES: 4522 219
Total SES: 10 0
Total UAS: 53 53
1 REPLY
Fixes: 76
Re: B.B. very slow loading pages laptop and desktop and youtube buffers
I can see from the subsequent responses to ticket 131447290 that the issue appears to be resolved. Do let me know if you're still experiencing issues though.
 Adam Walker
