Awful, awful speeds since 'upgrade' to 21CN
mrmarkus1981
Does everything here look ok to the tech guru's  Wink
I was getting the full 8MB line on ASDLMAX, now i get 2MB (ishj)
niko
Re: Awful, awful speeds since 'upgrade' to 21CN
try running the bt speed tester
my broadband tester is not working properly at the moment
mrmarkus1981
Bt Speed Tester doesnt work either  Huh
Fixes: 62
Forget speed tests - your problem is sync speeds which are awful.
Please connect the router to the test socket (behind the master socket removable bit) with nothing else connected and report the stats again
Which model Belkin Router is it
niko
well spotted i missed that ,
if there was an 8meg sync on adslmax i doubt its the house  wiring
Fixes: 62
There are several possibilities varying from BT screwed up the move to 21CN/ADSL2+ through to a filter going wrong or the router not supporting ADSL2+
It is always necessary to carry out the test socket bit first before raising a fault.
mrmarkus1981
I restarted the router, for the umpteenth time and now get this!!!  Perhaps i jumped the gun complaining too early Lips are sealed
Still, i thought i'd get better than the 8MB i had before with this 'upgrade to 20MB'
mrmarkus1981
Its a VERY old belkin router but Jo said i wouldnt need to change it. There is no way it supports ADSL2
Fixes: 62
You will need to wait for the Plusnet profile to increase - if it doesn't it can be kicked on Monday
I do however recommend getting a new router (via Plusnet or buying one) as the lack of support for ADSL2 may well be part of or indeed all of the problem
mrmarkus1981
I think i'll buy one as sadly* i think i may be leaving plusnet shortly and dont want to be tied for a year  Embarrassed
*my girlfriend will be moving in and she is tied to a sky contract (tv,phone & broadband)
Fixes: 10
mrmarkus1981
Still not getting anything above 8MB with new ADSL2+ router
ADSL Link Downstream Upstream
Connection Speed 20860 kbps 1184 kbps
Line Attenuation 15.0 db 2.8 db
Noise Margin 4.1 db 6.2 db
matt_2k34
i would imagine either the BT IP profile is still capped at 7150 or the PN one is (which is Here)
That should update in (up to around) 3 days - keep the router sync'd (no reboots or turning it off) - if the BT one has sped up its normally 12 hours from then for PN to follow suit Smiley -- unless a member of staff prods it for you.
The BT speedtester should give you the IP profile when you get the results of the test Smiley
Regards
mrmarkus1981
If a Plusent supremo could intervene and check that would be just peachy  Grin
dfunked
Quote from: Matt_2k34
There's a bit of a problem at the moment with plusnet profiles not matching up automagically;
http://community.plus.net/forum/index.php/topic,101517.128.html
Sorry to say it, but it looks like the OP jumped the gun a bit and unnecessarily bought a new router when the plusnet profile just needed a bump...
