Awful FTP speed with Plus.net - is this normal?
- Awful FTP speed with Plus.net - is this normal?
18-11-2009 5:38 PM
Hello, I have a number of properties and use several ISPs. The only one I'm having trouble with is Plus.net.
The FTP speed is terrible. It takes around 13 seconds to upload a 2kb file. Can someone please post advice on what to do?
Tom
Tom
Message 1 of 9
(1,440 Views)
8 REPLIES 8
Re: Awful FTP speed with Plus.net - is this normal?
18-11-2009 5:45 PM
Try FTP COMMANDER... or Filezilla.... it may be the FTP client you are using, and not PN. !
Message 2 of 9
(711 Views)
18-11-2009 5:52 PM
Quote from: shutter Try FTP COMMANDER... or Filezilla.... it may be the FTP client you are using, and not PN. !
I use CuteFTP and should be able to use any FTP program. There's some kind of a problem with PlusNet it seems.
Message 3 of 9
(711 Views)
18-11-2009 6:04 PM
Just a quick note - I've tried FileZilla - same problem. Over 10s to upload files - it's now 18.04.
Message 4 of 9
(711 Views)
18-11-2009 6:23 PM
what package are you on some are throttled to non PN sites see http://www.kitz.co.uk/isp/plusnet_shaping.htm
Message 5 of 9
(711 Views)
18-11-2009 6:25 PM
It's plusnet premium...
I see it's throttled down to 256Kb on that package. But surely I should be able to upload a 4kb file in under 13 seconds?
Message 6 of 9
(711 Views)
18-11-2009 6:34 PM
not necessarily so A) we are on Plan B restriction, B) the 256 is the maximum, FTP etc are scheduled behind VOIP and gaming as shown on the bottom of that page, and will thus run even slower at peak times
Message 7 of 9
(712 Views)
18-11-2009 9:48 PM
Quote from: pierre_pierre not necessarily so A) we are on Plan B restriction, B) the 256 is the maximum, FTP etc are scheduled behind VOIP and gaming as shown on the bottom of that page, and will thus run even slower at peak times
Hey Piere, thanks for the help. That sounds exactly like what's going on.
I've upgraded to Pro - which appears unrestricted. I'll update you if it fixes the problem.
Thanks again
Tom
Message 8 of 9
(712 Views)
Re:Awful FTP speed with Plus.net - is this normal?
19-11-2009 3:52 PM
Hi TomA09,
Let us know if you have any more issues and we'll take a look.
Message 9 of 9
(712 Views)
