Autoturn server and FINGER command
- Autoturn server and FINGER command
12-08-2007 10:35 AM
FINGER POSTMASTER@AUTOTURN.PLUS.NET returns my IP address successfully, followed by the ERROR message: Finger: read::Connection reset by peer.
It should return the number of emails queued on the autoturn server. Am using fixed IP and SMTP to my NS Exchange server, but error is reported from any pc on the network.
Does anyone know whetehr this error is being returned from PN Autoturn server or from FINGER cmd timing out?
I can ping PN Autoturn derver in 20ms.
Message 1 of 9
(4,274 Views)
8 REPLIES 8
Re: Autoturn server and FINGER command
12-08-2007 11:37 AM
Are you doing this from a Windows system?
My understanding is this is how Windows handles the connection close.
A number is only returned when messages are waiting for delivery. The absence means no messages are waiting.
Message 2 of 9
(909 Views)
12-08-2007 11:57 AM
Yes, this is from a Windows system.
I used to get a reply saying "0 messages queued"
[autoturn.plus.net] is returned 'instantly'.
IP address [CR] and the error message is returned after approx 23 secs - may indicate some sort of time-out
Message 3 of 9
(909 Views)
12-08-2007 2:43 PM
I think Autoturn stopped displaying the "0 messages queued" message a month or two back when it was rebuilt. The message you get is normal for Windows, this is what I get
C:\Documents and Settings\Administrator.CACTUSJACK>finger postmaster@autoturn.pl
us.net
[autoturn.plus.net]
8> Finger: read::Connection reset by peer
In Debian I get
dave@colinux:~$ finger postmaster@autoturn.plus.net
[autoturn.plus.net]
XX.XX.XX.XX
us.net
[autoturn.plus.net]
In Debian I get
[autoturn.plus.net]
XX.XX.XX.XX
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 4 of 9
(909 Views)
12-08-2007 9:43 PM
Dave,
Helpful reply, but not sure why?
PN Help suggests all over the place that the finger comnmand returns the number of emails held on the autoturn server. I would expect 0 if 0 held!
Finger uses port 79, apparently, I am currently trying to pass port 79 through firewall(s) to see if a proper response is returned. Maybe MS has patched a firewall to block this port?
Message 5 of 9
(909 Views)
12-08-2007 11:24 PM
If there are emails waiting I get the number, e.g. this from this morning (this is from a Debian cron job)
[autoturn.plus.net.uk]
XX.XX.XX.XX
Your IP address is XX.XX.XX.XX
1 messages queued
Email delivery triggered to XX.XX.XX.XX
Not sure about a Microsoft patch, the machine I use is Windows 2000 so doesn't have the Microsoft firewall, might have to do some wireshark packet captures to see if I can see any difference.
XX.XX.XX.XX
1 messages queued
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 6 of 9
(909 Views)
13-08-2007 1:18 PM
Quote from: cockleybarn Dave,
0 is no longer returned since the appearance of the reset by peer message. The way to test the finger commend is to switch your server off and send an email from another account, like google mail, and then do the finger commend.
Message 7 of 9
(909 Views)
13-08-2007 11:33 PM
Quote from: itsme 0 is no longer returned since the appearance of the reset by peer message. The way to test the finger commend is to switch your server off and send an email from another account, like google mail, and then do the finger commend.
I understand the principle of what you are saying & I'll disable the Exchange Server polling temporally and test it as you suggest. I'm * sure * that it used to give a '0 messages' response! Anyway, if I get a '1 message queued' response which goes away upon reconnection, then all will be well and normal!
Thanks to all for help
Message 8 of 9
(909 Views)
13-08-2007 11:50 PM
Yeah, it did used to give the "0 messages" so you aren't imagining things. About 2 months or so ago we upgraded Autoturn to give it some new hardware and more resiliancy but I think at the same time it stopped doing the "0 messages".
Dave Tomlinson
Plusnet Technology
Plusnet Technology
Message 9 of 9
(909 Views)
