Automating gateway hoping
- Automating gateway hoping
25-05-2013 5:52 PM
Re: Automating gateway hoping
25-05-2013 6:35 PM
25-05-2013 6:50 PM
if I ping out to anywhere I see the same kind of increase, and my plan was to define a "good" ping time and on connect test the connection. I've seen this phenomenon ever since joining plusnet.
Even 15ms ping is really good, so don't get me wrong I'm not complaining, but if for a little effort I can be more likely to have a good connection then I'll do it
25-05-2013 7:04 PM
25-05-2013 7:07 PM
25-05-2013 7:14 PM
25-05-2013 7:20 PM
25-05-2013 9:21 PM
Ex-Broadband Service Manager
25-05-2013 9:39 PM
Today:
My Broadband Ping
19th:
My Broadband Ping
18th:
My Broadband Ping
9th:
My Broadband Ping
8th:
My Broadband Ping
7th:
My Broadband Ping
3rd:
My Broadband Ping
25-05-2013 9:44 PM
Would you like a list Kelly I've been compiling one, every time I change Gateways. I can certainly tell you which ones are rubbish (for me anyway)
To be fair I have noted some improvements, presumably because of some of the work you've been doing. I'll have tocompare my list with what jimbof has posted.
25-05-2013 9:52 PM
Good:
pcl-ag08
ptn-ag01
pcl-ag02
"Bad":
ptw-ag01
pcl-ag06 ?
25-05-2013 11:23 PM
26-05-2013 5:38 AM
For me last night over this number of tests it seems like all of pcl-ag01-06 could become quite slow ping wise, with pcl-ag03 putting in the worst performance of all. Though those gateways aren't permanently bad it seems - If you look further down the list you can see often a gateway which has performed poorly can then have a much better result within a short timeframe, whereas my experience is that typically once connected with slow pings you are stuck at that ping for the session duration. Weird.
18.115 pcl-ag03 - Sun May 26 00:25:04 BST 2013
14.036 pcl-ag01 - Sun May 26 00:15:51 BST 2013
13.647 pcl-ag06 - Sun May 26 00:00:29 BST 2013
13.591 pcl-ag02 - Sat May 25 23:57:24 BST 2013
13.426 pcl-ag01 - Sun May 26 00:34:17 BST 2013
13.315 pcl-ag05 - Sun May 26 00:43:30 BST 2013
13.297 pcl-ag04 - Sun May 26 00:37:21 BST 2013
12.097 pcl-ag06 - Sat May 25 23:23:37 BST 2013
10.244 ptw-ag04 - Sat May 25 23:35:54 BST 2013
10.179 pcl-ag04 - Sat May 25 23:29:45 BST 2013
10.062 pcl-ag01 - Sat May 25 23:26:41 BST 2013
10.029 pcl-ag04 - Sun May 26 00:18:55 BST 2013
9.914 ptw-ag02 - Sat May 25 23:51:16 BST 2013
9.898 pcl-ag01 - Sun May 26 00:06:38 BST 2013
9.893 pcl-ag06 - Sun May 26 00:21:59 BST 2013
9.836 ptw-ag02 - Sat May 25 23:48:11 BST 2013
9.826 ptn-ag02 - Sat May 25 23:45:07 BST 2013
9.807 ptn-ag02 - Sat May 25 23:38:58 BST 2013
9.732 ptn-ag04 - Sat May 25 23:32:50 BST 2013
9.661 ptw-ag03 - Sat May 25 23:42:03 BST 2013
9.511 pcl-ag06 - Sun May 26 00:09:42 BST 2013
9.480 ptn-ag02 - Sun May 26 00:03:33 BST 2013
9.470 ptn-ag01 - Sat May 25 23:54:20 BST 2013
9.420 pcl-ag03 - Sun May 26 00:12:46 BST 2013
9.391 pcl-ag04 - Sun May 26 00:28:08 BST 2013
9.352 pcl-ag04 - Sun May 26 00:31:12 BST 2013
9.290 ptw-ag04 - Sun May 26 00:40:26 BST 2013
26-05-2013 6:43 AM
- testing just after midnight might not give reliable results as a number of users will have scheduled large downloads because of the free overnight usage - not everyone is on unlimited usage remember.
- Stay on each Gateway somewhat longer and see how much variability you get over time - especially the ones that appear worse. What I find is that for me, slower gateways never get better than a minimum value, but they do get a lot worse at times, as do the better ones at times. I see you have a ping plotter running.
I've been plotting my pings lately to investigate a completely different issue and have seen some interesting patterns that I've yet to analyse and look at in depth - and to be sure it's nothing to do with the program I'm currently plotting with.
- When you connect to a Gateway, do a tracert to the same IP address each time (maybe the one you are pinging) and log it. See if any of the intermediate hops change for the same gateway and whether this shows any particular routing as being bad.
- Check your Router logs each time you connect to a Gateway and see if you are connecting via the same bras node each time.
26-05-2013 7:20 AM
i have no idea why but it is between 1700 - 2100 they are at their worst, sorry i haven't any test to show this
