Automatically move spam false positives back to inbox?
- Automatically move spam false positives back to in...
14-03-2008 9:27 PM
I seem to recollect a comment (in one of the threads about Positini false positives) which suggested that when reporting a false positive it was possible to automatically remove the [-SPAM-] in the header and return the mail to the appropriate inbox. Possibly this was with Webmail? I can't find it described anywhere. Anyone know if it was true and if so where is it documented?
Message 1 of 3
(902 Views)
2 REPLIES 2
Re: Automatically move spam false positives back to inbox?
14-03-2008 11:33 PM
Yes, it can be set in webmail to be moved into the Inbox automatically after reporting as notspam but you can't remove [-SPAM-] from the header (as far as I'm aware!).
Log into your account and go to Options from the menu at the top of the page. From the Options, choose Display Preferences and then scroll right down to the bottom of the page, where you will find the Spam Reporting settings. Then just choose "Inbox" for "Move Non-Spam After Reporting To:" and there you have it.
Don't forget to click on "Submit" to save your changes.
Hope this helps.
Hope this helps.
Plusnet user since November 2003
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
Message 2 of 3
(303 Views)
15-03-2008 1:32 PM
Thanks. You are right, unfortunately it doesn't remove the [-SPAM-] from the subject line.
Not really useable without that.
Maybe PN could put that on the to-do list?
Message 3 of 3
(303 Views)
