Auto reset modem?
- Auto reset modem?
Auto reset modem?
09-06-2012 11:55 PM
I have a Thomson TG585 v7 modem. Occasionally I have to reset the power on the modem to get back online. This is problematical owing to the fact I run a number of websites from home. This loss of connection seems to occur in the early hours of the morning so presumeably some maintenance has been carried out. Is there a setting (or even a different modem) that can enable the modem to reset itself after a disconnection?
Regards
Re: Auto reset modem?
10-06-2012 2:42 AM
Using a TG585v8, during the recent BTw works, I was assigned a 172.x.x.x IP for a while, but after a few minutes the session dropped again. The proper connection automatically restored itself about 4 hours later when I assume BTw finished their work.
If it's sync with the local exchange that is lost I would expect the router to keep trying to reconnect, then move onto and restore the PPP session once sync is achieved.
10-06-2012 8:13 AM
Quote from: spraxyt If it's sync with the local exchange that is lost I would expect the router to keep trying to reconnect, then move onto and restore the PPP session once sync is achieved.
I am not sure what the problem is or has been but the only way I can reconnect is to power off the modem and let it restart once more.
11-06-2012 8:36 AM
http://usertools.plus.net/status/archive/1338976404.htm
http://usertools.plus.net/status/archive/1338213249.htm
http://usertools.plus.net/status/archive/1337612069.htm
http://usertools.plus.net/status/archive/1337006539.htm
Note - there's a chance that you may be disconnected from the internet for a period of time during the maintenance window. This work may affect users nationwide. (due to the nature of the broadband network these outages may affect customers nationwide.)
11-06-2012 1:28 PM
Quote Note - there's a chance that you may be disconnected from the internet for a period of time during the maintenance window. This work may affect users nationwide. (due to the nature of the broadband network these outages may affect customers nationwide.)
It does appear to be maintenance and I appreciate the fact that the work tends to be carried out in the early hours of the morning. What is bothering me though is the fact that the modem does not auto-connect again. Or if it does appear to be so the broadband still doesn't work until I power off and back on. I have a static ip address on this line. Don't know whether that is making any difference to auto-reconnect.
11-06-2012 5:11 PM
We can't work out exactly why that happens, but what we need is someone who has not connected automatically to leave it so while we get BT to look at it. Once a customer reconnects we can't see what's caused it.
Jojo
11-06-2012 6:05 PM
dick:quote
11-06-2012 6:14 PM
11-06-2012 8:07 PM
11-06-2012 8:51 PM
12-06-2012 9:44 AM
Quote from: Bluesplayer What you could do...is...wait for it...setup an indentical scenario your end. Use my type of modem and see if the problem occurs whenever maintenance is carried out. Now that would be a perfect answer.
Yes, we have/are and have not been able to replicate it as yet.
12-06-2012 10:25 AM
12-06-2012 10:13 PM
Following a remote disconnection, the router reports it has reconnected (with a new IP address) but there is no access to the internet.
Logging into the router and 'disconnecting' then 'reconnecting' very often restores internet access (with another IP address) but sometimes a reboot is necessary.
Mike
