Authentication fails on router, but works fine on website??
- Re: Authentication fails on router, but works fine...
25-09-2009 7:21 AM
Hi all,
As per title really. Was switched onto 21cn yesterday (24th). I've got sync and the router is detecting 2+ but the username and password are being rejected (I've checked syslog and maintenance on dsl-2640b which confirm this), even though the user and password are fine on here.
Here's my settings:
(My username)@plusdsl.net
Vci/vpi 0/38
PPPoA/VC-Mux
I tried changing my password on the website, which worked, but I'm still getting auth errors on the router.
If there's any Plus staff around can you check for a stale session etc on my line? Cheers.
Here's my settings:
Vci/vpi 0/38
PPPoA/VC-Mux
Message 1 of 3
(912 Views)
2 REPLIES 2
Re: Authentication fails on router, but works fine on website??
25-09-2009 9:51 AM
Hiya,
Is your router using the most recent version of Firmware?
I'm not seeing any attempted connection attempts from our end.
Message 2 of 3
(300 Views)
25-09-2009 8:56 PM
Does your router get the PPP authenticated ?
I know mine was not authorising - the reason behind this was the PPP was not connecting/authenticating properly
Try changing it from PPPoA VC mux to ... PPPoA LLC ... and try onnecting again.
(IMy router is similar, its a DSL-2740B Router btw)
Message 3 of 3
(300 Views)
