Attenuation increase from 25 to 50
- Attenuation increase from 25 to 50
- « Previous
- Next »
Re: Attenuation increase from 25 to 50
19-08-2014 9:16 PM
I think i will wait a bit and see how the connection performs after the IP profile updates. I don't know any local BT engineers but i can ask around and maybe find someone to do it for me. The extension i could fit myself as i am fairly competent at DIY, if you could point me to the cable supplier and instructions on how to fit it that would be helpful.
Ron
Ron
Message 31 of 34
(269 Views)
19-08-2014 9:58 PM
Cable and IDC Tool also if you want Cable clips though you could probably get a smaller quantity at a good ironmonger.
Personally I'd get enough cable to do the whole lot. Do your extension & also lay the cable in place from the box in the loft to the master. Then if you feel confident, do it yourself, otherwise very little for a BT man to do, just make the connections.
The cable is twisted pair which is why it's not vulnerable to interference in the way the old cable is. This one is 2-pair. There is 3-pair, but you only need 1 pair, so 2-pair is fine.
The Pair to use is the Blue+white trace and the White+blue trace. From master to extension the Blue+white trace goes to terminal 2 and the White+blue trace goes on terminal 5. The bell wire you don't use in a Broadband situation, it unbalances the pair and acts like an aerial, otherwise the Orange/white would have gone on 3. You'd use it if you had central filtering, but with plug-in filters they generate their own locally for a phone.
From the box in the loft, the Blue/white would connect to the terminal that has the White incoming (B-wire) and probably has a solid blue colour on it atm. The White/blue trace would go on the terminal with the orange incoming (A-wire) and probably has the orange solid colour on it atm.
At the back of the master, the Blue/white goes to B, and the White/blue to A.
You do not strip the wire, it's pushed down into the IDC (Insulation Displacement Connector) terminal with the tool - never use a screwdriver or similar as it would force the jaws of the terminal open making a bad connection. Old wires you just pull vertically out of the terminal.
HTH, ask away if I've missed something or you aren't sure of something.
Message 32 of 34
(269 Views)
19-08-2014 10:26 PM
Thanks, i think i should be able to do this myself but if i am stuck with anything i will certainly ask.
Your help and advice is much appreciated.
Ron
Ron
Message 33 of 34
(269 Views)
19-08-2014 10:41 PM
No problem.
Message 34 of 34
(269 Views)
- « Previous
- Next »
