Attainable rate dropped?
- Attainable rate dropped?
17-04-2013 1:35 PM
I've submitted a support ticket but no response yet...
When I first had fibre installed the attainable rate was 65mb... This is now sitting at 48mb....
Any ideas what it can be? Bit of a pain!
Also any info on fttpod yet?
Message 1 of 8
(1,645 Views)
7 REPLIES 7
Re: Attainable rate dropped?
17-04-2013 1:51 PM
Message 2 of 8
(895 Views)
18-04-2013 4:04 PM
Had a reply,,, basically saying that the attainable rate is an estimate and cant be relied on.. fair enough...
but i was connecting at 65mbit and now its 50, so it shouldnt drop that much should it?
Message 3 of 8
(895 Views)
18-04-2013 5:01 PM
How long were you connected at 65Mbps for?
Message 4 of 8
(895 Views)
19-04-2013 4:32 AM
What was your original estimated speed?
As take-up increases in the cabinet, crosstalk from other customers will reduce your speed, and/or increase errors which are likely require the addition of interleaving and FEC - so reducing speed further.
BT's original speed estimates were pessimistic because they already accounted for this effect. But take-up rates mean we're still in the process of seeing the effect in practice.
How much speed can be lost? The overheads of FEC, when turned on, can instantly take away between 10% and 25% of your speed. On top of that, more speed can be lost by the increase in interference/noise that doesn't cause errors. Perhaps 40% overall - but every line suffers differently.
Your drop of 65-50 is very close to 20%, so it is highly likely that the majority comes from just having interleaving and FEC turned on. If you are around your estimated speed, then this is even more likely to be the case.
The solution is vectoring, which should take away all the crosstalk, and restore service back to close to pristine. In the reports describing how good vectoring is proving to be, the graphs that show the improvement also imply (in reverse) just how much speed can be lost as your neighbours add to the take-up on the cabinet.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 5 of 8
(895 Views)
19-04-2013 7:40 AM
interesting article and may well be something they do on my line (eventually, who knows when with OR lol)
It refers to copper loop length but people on here typically say how far they are away from their cabinet. So is the loop length likely to be double the distances people quoted e.g. I'm about 300m away as the crow flies so would loop length be 600m?
Message 6 of 8
(895 Views)
19-04-2013 11:55 PM
No - loop length means the same as the distance to the cabinet.
Plusnet Customer
Message 7 of 8
(895 Views)
20-04-2013 11:48 AM
Cool. I did wonder as my 73/17 line rate would be exceptional for 500-600m lol
Message 8 of 8
(895 Views)
