Attainable Rate
- Attainable Rate
Attainable Rate
11-07-2015 4:17 PM
Re: Attainable Rate
11-07-2015 4:45 PM
How long is it since you power-cycled your router? Preferably with a ten-minute interval between off and on?
Re: Attainable Rate
11-07-2015 4:52 PM
Re: Attainable Rate
11-07-2015 5:40 PM
SNR Margin (dB) 3.6 14.9
Attenuation (dB) 56.0 34.3
Attainable Rate (Kbps) 2736 708
Rate (Kbps) 1810 440
Router has been connected for nearly 2 days now (I changed the router 2 days ago)
What's the difference between rate and attainable rate?
Is there anything I can do to get my speeds back up to 2Mbps?
Re: Attainable Rate
11-07-2015 10:20 PM
The low SNR Margin suggests either you are tweaking it or there could be a lot of variable noise. Did you change the router because of earlier problems, and are you tweaking?
I'm trying to find out what has been going on in the recent past and what problems you've had, as I'm surprised you could only download at 2Mbps some time in the past. The 56dB attenuation suggests much higher than that should be possible. As though you have a long-standing poor connection that has got worse.
Re: Attainable Rate
12-07-2015 6:23 AM
Re: Attainable Rate
12-07-2015 10:28 AM
Exchange: Kells BT Code: NIKS
I've tweaked the SNR (lowered by 2) in an attempt to get a higher sync speed. It doesn't seem to make any difference though. The line is currently stable though I've never really had a problem with stability - it's just the download speeds aren't what I'd like.
Re: Attainable Rate
12-07-2015 10:41 AM
Connection Time 2 Day(s) 15:50:36
xDSL
Mode ADSL_2
Traffic Type ATM
Status Up
Link Power State L0
Downstream Upstream
Line Coding (Trellis) On On
SNR Margin (dB) 3.8 14.9
Output Power (dBm) 0.0 12.7
Attainable Rate (Kbps) 2764 712
K (number of bytes in DMT frame) 0 0
R (number of check bytes in RS code word) 0 0
S (RS code word size in DMT frame) 0 0
D (interleaver depth) 64 8
Delay (msec) 7 8
INP (DMT symbol) 4.00 2.00
Super Frames 14199219 12598074
Super Frame Errors 538 87
RS Words 1959492317 1799861
RS Correctable Errors 18373538 1799
RS Uncorrectable Errors 11936 0
HEC Errors 2500 100
OCD Errors 84 0
LCD Errors 84 0
Total Cells 979740040 237802450
Data Cells 192523313 33219515
Bit Errors 0 7018
Total ES 278 53
Total SES 1 0
Total UAS 0 0
Re: Attainable Rate
12-07-2015 11:29 AM
Re: Attainable Rate
12-07-2015 11:56 AM
http://www.amazon.co.uk/gp/product/B003H6GUNA?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
It didn't really make any difference. Prior to that I was connecting a splitter directly into the master socket
There is no extension wiring
Re: Attainable Rate
12-07-2015 12:44 PM
Quote from: ejs The 440 upload, and 1810 not being an exact multiple of 32 suggests this is an ADSL2/2+ connection
Yes, that's why I said it was strange unless the IPStream product had changed. The stats in a later post are showing ADSL2, (not 2+?), and the exchange is WBC-enabled. I was confused by the 1.5Mbps IP Profile. I didn't check 88.2% of 1810, as my subconscious said it would be higher. But - 1,596.42.
Re: Attainable Rate
12-07-2015 12:53 PM
Does it always re-sync at 1810kbps?
You say you used to get over 2Mbps. As I said before, I would expect a lot more. Have you ever had it in the 3-4Mbps range, and when did it start to degrade from over 2 to the current under 1.5?
Does anything on this page look relevant? I assume the router is not sitting on top of or very close to some other electrical/electronic equipment.
Re: Attainable Rate
12-07-2015 2:59 PM
I'll try resyncing again later to check what speed I get - but I'm pretty sure it's always syncing around 1800 kbps
The fastest I've ever seen was around 2.2 Mbps. I'm not sure exactly when the speed dropped (I haven't been using it a lot) but it's been like this for a good few months
The router is sitting right beside the NTE along with a phone and a homeplug adapter
Re: Attainable Rate
12-07-2015 3:24 PM
Those ADSL stats did show interleaving was at a fairly high depth, and there were quite a lot of corrected errors, which suggests there is some sort of noise or interference affecting your broadband.
Re: Attainable Rate
12-07-2015 3:28 PM
xDSL
Mode ADSL_2
Traffic Type ATM
Status Up
Link Power State L0
Downstream Upstream
SNR Margin (dB) 4.3 14.9
Attenuation (dB) 57.5 34.4
Output Power (dBm) 16.8 12.7
Attainable Rate (Kbps) 2176 708
Rate (Kbps) 1718 440
Delay (msec) 8 8
Super Frames 15996 14211
Super Frame Errors 0 0
RS Words 0 0
RS Correctable Errors 0 0
RS Uncorrectable Errors 0 0
HEC Errors 0 0
OCD Errors 0 0
LCD Errors 0 0
Total Cells 0 0
Data Cells 0 0
Bit Errors 0 0
Total ES 0 0
Total SES 0 0
Total UAS 142 142
