Atrocious speeds this morning
- Re: Atrocious speeds this morning
23-05-2010 12:36 PM
Just wondering if anyone else is experiencing atrocious speeds today? Last night my connection was fine, however this morning everything is running extremely slowly. I have just run a BT Speedtest which came out at 62kbps - it's usually at 6500kbps+ (I'm syncing at 8128kbps/832kbps).
I've tried hopping gateways, rebooting the router and hooking directly into the master socket - still no joy. Given that the sync-rate is fine, I'm guessing it's something at the exchange side of things (I can't imagine it's PlusNet's end, as I'm sure the forums would be ablaze! )
I also tried following the next step on the speedtester (changing username to bt_test_user@plusdsl.net etc.), however this didn't seem to work.
Any thoughts / suggestions welcome - I'm on the East Leake (EMESTLE) exchange.
Cheers!
23-05-2010 4:38 PM
23-05-2010 11:55 PM
24-05-2010 10:01 AM
Download speedachieved during the test was - 7 Kbps
For your connection, the acceptable range of speeds is 1200-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 832 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
24-05-2010 10:23 AM
24-05-2010 10:27 AM
Some further background information for you: the problem occured overnight between Saturday and Sunday. Absolutely nothing has changed at my end, so I've got no idea what's happened. mybroadbandspeed.co.uk won't even load on the connection, however I was able to run the speedtest.net app on my android phone (hooked up to the wifi) - this registered an equally pathetic download speed, however the upload speed appeared to be fine
24-05-2010 1:31 PM
Has any action been taken on this? Just run another BT Speedtest which has come out at a more respectable 6371kbps. Connection now appears to be normal...again, nothing has changed at my end.
Looks like my ticket was taken off hold early, so maybe BT poked something?
Cheers,
-Paul
24-05-2010 1:40 PM
24-05-2010 5:37 PM
Is it sorted now from your point of view?
24-05-2010 5:49 PM
Browsing, e-mail etc. seems to be fine (speedtests are back to normal too) - however, I'm still having some Xbox Live issues (it's running extremely slowly, and I can't seem to connect to any games - normally it's fine at this time of night). Running a few tests now to try and figure out what's going on...will report back ASAP.
Thanks for taking a look - out of interest, does it mention what the fault was? Or do BT not provide that level of detail?
24-05-2010 5:51 PM
The next step is going to be an engineer if we reject the fixed status, which indicated they haven't found anything immediately obvious.
Have you rebooted since the speeds returned?
24-05-2010 6:51 PM
I have indeed - I've just rebooted again in an attempt to cure the Xbox Live problem. Previously I was on an "unknown" gateway, then PCL-AG03, and now PCL-AG01 - all have the same problem. I can connect to Xbox Live, however when I fire up Modern Warfare 2 it takes an age to update the playlist / unlock information, and then it won't let me join any games. The rest of my connection appears to be functioning as normal, so I'm not too sure what's up.
I'm about to head out for the evening, however I'll do some further tests when I return and let you know the outcome. Thanks for following up on this!
25-05-2010 10:11 AM
Still having Xbox Live issues, although I'm almost certain it's router related. The Xbox complains about incorrect MTU settings and ICMP response errors - I've had this problem before with this router, but I can never remember what causes it - the problem just seems to appear and then vanish randomly. Unfortunately I've had to hand the other router I was using to test back to it's owner, however I'll try and get a hold of it again this afternoon so that I can confirm.
Apologies for the delay in getting this information back to you - I'll let you know the result ASAP.
25-05-2010 10:28 AM
All fixed. Turns out that the Netgear DG834G appears to view Xbox Live as a DOS attack source I've disabled DOS protection on the router, and everything appears to be fine. I'd reset my router to factory settings as part of my tests, and I guess I just forgot to disable the DOS protection again.
I'll go ahead and close the support ticket - many thanks for your swift help and perserverence in this matter. I never begrudge paying you guys each month - and quality service like this is the reason why!
25-05-2010 10:48 AM
