Asus router - The setting of Dynamic Ip or Static IP connection is not valid?
tooslow
I have connected an Asus modem router up ( DSL N11) and all works fine until every half hour the connection drops with a message on the router page:
"The setting of Dynamic Ip or Static IP connection is not valid"
Anybody any idea how to fix  this?
Fixes: 55
Re: Asus router - The setting of Dynamic Ip or Static IP connection is not valid?
Have you got a timeout set in the connection settings on the router ?
tooslow
Quote from: MisterW
Timeout is set at 20?
What should I set it at?
Fixes: 162
You should be able to set it a 0, this would mean there is no timeout on most routers.
 Chris Parr
 Plusnet Staff
tooslow
Quote from: Chris
Have done, thanks. Hopefully, this will resolve the issue.
Ps. Is it necessary to have UpnP ticked 'on'? Or better to not to have it on?
