Asus router - The setting of Dynamic Ip or Static IP connection is not valid?
- Re: Asus router - The setting of Dynamic Ip or Sta...
02-01-2015 4:30 PM
I have connected an Asus modem router up ( DSL N11) and all works fine until every half hour the connection drops with a message on the router page:
"The setting of Dynamic Ip or Static IP connection is not valid"
Anybody any idea how to fix this?
Message 1 of 5
(871 Views)
4 REPLIES 4
Re: Asus router - The setting of Dynamic Ip or Static IP connection is not valid?
02-01-2015 4:59 PM
Have you got a timeout set in the connection settings on the router ?
Message 2 of 5
(510 Views)
02-01-2015 5:11 PM
Quote from: MisterW Have you got a timeout set in the connection settings on the router ?
Timeout is set at 20?
What should I set it at?
Message 3 of 5
(510 Views)
02-01-2015 5:12 PM
You should be able to set it a 0, this would mean there is no timeout on most routers.
Message 4 of 5
(510 Views)
02-01-2015 5:18 PM
Quote from: Chris You should be able to set it a 0, this would mean there is no timeout on most routers.
Have done, thanks. Hopefully, this will resolve the issue.
Ps. Is it necessary to have UpnP ticked 'on'? Or better to not to have it on?
Message 5 of 5
(510 Views)
