Moved to PN fibre and am trying to get VPN working with the ASUS n66u. I have set the VPN server part of the router up and can see incoming connections to the router in the "VPN status" part, but the incoming connection is not actually connecting to the PC on my LAN. Do I also need to forward the port (1723) to the PC's internal ip address or should the server in the router just pass the connection through? Is there anything else I've missed here?
Firmware 3.0.0.4.374_720
