Asus n55u router okay with Plusnet?
- Asus n55u router okay with Plusnet?
20-05-2013 5:22 PM
Any problems or useage tips?
Cathy
Re: Asus n55u router okay with Plusnet?
20-05-2013 6:44 PM
Quote Most people on this forum seem to have the Asus n66u, but I think that is for fibre and I'm on ADSL.
You are correct. The n55u should work fine on ADSL, I've no idea about its wireless performance though.
Might you migrate to Fibre in future ? the n55u will be useless in this case. If that's likely then you might want to look at something with Dual band Wifi that has both ADSL and WAN capabilities
such as the Netgear DGND3700 or the tp link TD-W8980.
Or even, if you don't mind 2 separate boxes then it's possible to configure the TG582n as just an ADSL modem and use the Asus n66u.
Edit: according to this http://forums.thinkbroadband.com/multiuser/4206825-asus-n55u-on-plusnet-fibre-and-some-other-questio... it would appear that with updated f/w the n55u
could be used with Fibre although it did seem to have some problems.
20-05-2013 7:56 PM
20-05-2013 8:05 PM
20-05-2013 8:34 PM
Cathy
20-05-2013 9:06 PM
