Asus RT-N66U Plusnet Extra Fibre/BT Infinity
- Re: Asus RT-N66U Plusnet Extra Fibre/BT Infinity
02-03-2013 8:27 PM
I've decided to invest in a new router today, I went ahead and purchased a Asus RT-N66U with all the bells and whistles....
However I am unable to get it to play ball with my BT Infinity Plusnet Extra fibre connection.
I have set it up as many others have Using PPPoE Leaving every setting as automatic and enabling VPN/DHCP.
I cannot obtain a WAN connection and being quite tech Savvy this was naturally infuriating.
My setup as follows
Master socket -->BT OpenReach Fibre Modem-->ASUS RT-N66U
02-03-2013 8:54 PM
02-03-2013 9:02 PM
Jan 1 00:00:12 WAN Connection: Fail to connect with some issues.
02-03-2013 11:15 PM
03-03-2013 12:25 PM
Quote from: Draftrabbit However I am unable to get it to play ball with my BT Infinity Plusnet Extra fibre connection.
Small point, but the connection isn't BT Infinity...
Quote from: Draftrabbit I have set it up as many others have Using PPPoE Leaving every setting as automatic and enabling VPN/DHCP.
Not familiar with the router but you don't want to enable a VPN.
There's some info here:
http://community.plus.net/forum/index.php/topic,108770.0.html/
Worth noting the comments about taking 5 mins to get a connection (My router, running Gargoyle also takes this long!)
03-03-2013 2:40 PM
1. Surely with it being a BT Wholesale product it is leased as BT Infinity with a different name,
2. I reset the router completely (it was that or going out of a window!) and it gave me the original setup wizard and it detected my Connection type finally.
THANK YOU!
jim:quote
03-03-2013 3:16 PM
Quote from: Draftrabbit 1. Surely with it being a BT Wholesale product it is leased as BT Infinity with a different name,
No, Infinity is BT Retail's name for their fibre broadband product range. Not the name used by BTW, which is actually "Generic Ethernet Access Fibre to the Cabinet (GEA-FTTC)"
Glad you got there in the end with the RT-N66U. It's a decent router, so hopefully you'll be happy with it now it's actually online. Post back if you have any other problems with it. Lots of us here seem to use it so someone should be able to help.
03-03-2013 6:34 PM
03-03-2013 7:41 PM
Since Merlin's firmware is based on the original Asus firmware, but with some bug fixes and quite a few enhancements, it tends to be very stable. Not had any problems so far. But which firmware you use depends on what you need the router to do.
06-03-2013 8:34 PM
06-03-2013 9:12 PM
Are you on fibre or ADSL? (it makes a difference!)
10-03-2013 4:16 AM
10-03-2013 4:34 AM
Quote from: PasPer2 I'm on PN's fibre package and have the Technicolor router which does what I need it to do, I just wondered if I was missing out on something by using it whilst others had migrated away to another router.
I use the asus n56u router as i use a wirless connection and the n56u offers 5ghz band, we have a baby monitor that interferes with the 2.4ghz band.
10-03-2013 8:14 AM
I think the real reason to replace the PN 582n router is if you are having wireless issues - if not keep the free one!
10-03-2013 8:39 AM
Quote from: shalom2010 I think the real reason to replace the PN 582n router is if you are having wireless issues - if not keep the free one!
Spot on
A few people may also want features that either aren't available on the TG582n or are difficult to configure (eg only available using the telnet interface), or don't work well. For example, I need to be able to access my home network securely when I'm away from home, so I use the OpenVPN feature on the Asus router.
But as shalom2010 says, if it's working fine for you (and it does for many people), stick with it!
