Asus RT-AC51U
banana1
Asus RT-AC51U
I'm having trouble setting up a new router Sad
I have my RJ11? cable from the OpenReach modem to the new router. The wifi of the new router works but I have no internet (or WAN) connection.
I've used the details given here to try to set up PPPoE (though that page says PPPoA), using my Plusnet username@plusdsl.net and password (which let me in to the member's area).
If I remove the cable and plug it into my old (i.e. Plusnet's) router I can connect to the internet through that. There's an option to provide the MAC address, but I've seen advice that I don't need it - and how do I find it anyway?
I can't think of anything else to try. Does anyone have any ideas? Thanks!
banana1
Re: Asus RT-AC51U
I found the MAC address of the Plusnet router on the bottom and copied it into the settings, in case the router was whitelisted but it didn't work Sad
Fixes: 35
Re: Asus RT-AC51U
The MAC address is not needed, but you will need to set up a VLAN 101 I think, I am sure there are some setting on other threads. I am assuming as you mention an Openreach mode you are on Fibre?
SpendLessTime
Aspiring Hero
Fixes: 82
Re: Asus RT-AC51U
That page says this for "Using a router with an Openreach modem"
If your fibre router is connected to a BT Openreach modem, here are the settings you’ll need. Some of these terms can vary from router to router, but these are the most commonly used.
It asks for: Use:
Broadband username or login name yourusername@plusdsl.net
Connection type or encapsulation PPPoE Always On
Might be best to factory reset the new router.
Have you made sure the router firmware is upto date?
Fixes: 35
Re: Asus RT-AC51U
Have a look at this setup, its not the same router, but does sho the relevant settings.
banana1
Re: Asus RT-AC51U
I'm sorry, I have an ADSL modem plugged into the Openreach wall socket. I don't have Fibre, just ADSL
banana1
Re: Asus RT-AC51U
The WAN light on my router is not lit. Perhaps I have faulty hardware? Sad
SpendLessTime
Aspiring Hero
Fixes: 82
Re: Asus RT-AC51U
Is the ADSL modem sending the login details to Plusnet? If so, then the router wont need to do that.
Fixes: 35
Re: Asus RT-AC51U
Ah then you should be using PPoA.
