Asus RT-AC51U
- Re: Asus RT-AC51U
Asus RT-AC51U
21-12-2016 7:17 PM - edited 21-12-2016 7:18 PM
I'm having trouble setting up a new router
I have my RJ11? cable from the OpenReach modem to the new router. The wifi of the new router works but I have no internet (or WAN) connection.
I've used the details given here to try to set up PPPoE (though that page says PPPoA), using my Plusnet username@plusdsl.net and password (which let me in to the member's area).
If I remove the cable and plug it into my old (i.e. Plusnet's) router I can connect to the internet through that. There's an option to provide the MAC address, but I've seen advice that I don't need it - and how do I find it anyway?
I can't think of anything else to try. Does anyone have any ideas? Thanks!
Re: Asus RT-AC51U
21-12-2016 7:29 PM
I found the MAC address of the Plusnet router on the bottom and copied it into the settings, in case the router was whitelisted but it didn't work
Re: Asus RT-AC51U
21-12-2016 7:57 PM - edited 21-12-2016 7:59 PM
The MAC address is not needed, but you will need to set up a VLAN 101 I think, I am sure there are some setting on other threads. I am assuming as you mention an Openreach mode you are on Fibre?
Re: Asus RT-AC51U
21-12-2016 8:01 PM
That page says this for "Using a router with an Openreach modem"
If your fibre router is connected to a BT Openreach modem, here are the settings you’ll need. Some of these terms can vary from router to router, but these are the most commonly used.
It asks for: Use: Broadband username or login name yourusername@plusdsl.net Connection type or encapsulation PPPoE Always On
Might be best to factory reset the new router.
Have you made sure the router firmware is upto date?
Re: Asus RT-AC51U
21-12-2016 8:04 PM
Have a look at this setup, its not the same router, but does sho the relevant settings.
Re: Asus RT-AC51U
21-12-2016 8:22 PM
I'm sorry, I have an ADSL modem plugged into the Openreach wall socket. I don't have Fibre, just ADSL
Re: Asus RT-AC51U
21-12-2016 8:49 PM
The WAN light on my router is not lit. Perhaps I have faulty hardware?
Re: Asus RT-AC51U
21-12-2016 8:52 PM
Is the ADSL modem sending the login details to Plusnet? If so, then the router wont need to do that.
Re: Asus RT-AC51U
21-12-2016 9:08 PM
Ah then you should be using PPoA.
