Asus N56-U Config
- Asus N56-U Config
Asus N56-U Config
23-04-2013 12:57 PM
Hi all, I am trying to configure my Asus N56-U router as I am new to plusnet (ex infinity)
I have tried this config
With the password
Without the password
I have updated the firmware
Reset the router
Is the setting correct on this?
Thanks!
With the password
Reset the router
Thanks!
Message 1 of 7
(1,239 Views)
6 REPLIES 6
Re: Asus N56-U Config
23-04-2013 1:16 PM
You may want to remove or edit that image as it shows your username
Message 2 of 7
(556 Views)
23-04-2013 2:01 PM
So does his forum username, his email address and his rDNS if he has a static IP.....
Message 3 of 7
(556 Views)
23-04-2013 2:56 PM
Is the "User Name" entered on the router identical to the "Login Name" shown in "Connection Settings" on your Member Centre ?
I only ask as sometimes the generic username format given as examples elsewhere don't always work - although mostly a problem with older accounts such as Force9, etc, but worth double checking anyway.
Message 4 of 7
(556 Views)
23-04-2013 3:07 PM
As purleigh said when i set mine up it had a random name in as the username and password, i changed it to mine and everything worked, apart from that, thats how my setup page looks like and i have a RT N56u
Message 5 of 7
(556 Views)
23-04-2013 5:53 PM
Mine is set up exactly like that. My log in details are the ones I use for logging into plusnet as already stated. Hope you find your N56U as useful as I do mine.
Message 6 of 7
(556 Views)
23-04-2013 6:40 PM
same here, mine is setup exactly like that but with my info obviously
Message 7 of 7
(556 Views)
