Asus DSL-N66U any good ?
karlos103
Hi
Want to replace my BT homehub 5 with a better modem / router , was looking at a Fritz box 3390 but also found the a
Asus DSL-N66U  .....anyone have a review on this ?
Fritz box is only vdsl ...not vdsl2 like Asus .
Reviews on the net look good , after updating firmware .
Any input most appreciated
Karl
Re: Asus DSL-N66U any good ?
I have an Asus RT-N66U which I'm very pleased with. From what I've seen, Asus routers are in general pretty highly regarded.
Bob
karlos103
Many thanks for that Bob ....sounding good to me ...how you find wifi on it as that is supposed to better than most ?
cheers
karl
dick:quote
It's difficult to say but we have a fairly large house and both the 2.4g and 5g networks work in every room. I can say that the 2.4g signal is stronger than the Netgear DG834g router I used before.
The DG834g router was as solid as a rock and I tried several dual band routers as replacements but they all fell short with the exception of the Asus.
Bob.
karlos103
thanks for the info ...5ghz band is always weaker than 2.4ghz so thats fine with me ....but sounds good to me ...may just get one Smiley
There are quite a few PlusNet users. If you search this board you'll find quite a long thread on the RT-N66U.
Bob.
karlos103
Anyone else have any input on this ?
leader
Plusnet are/were(?) trailing the Thomson TG589
http://community.plus.net/forum/index.php/topic,117383.msg1015595.html#msg1015595
Might be worth asking one of the Digicare team (or ^Graham21 ^i]r ) if they still can be had..... Wink
pwatson
I would note that the RT-N66U and the DSL-N66U may have different wifi performance to each other.  The RT unit has external antennas but the DSL version doesn't.
There's a thread here about getting the DSL-N66U working on VDSL.  I don't think it was resolved...
More posts here - Looks like a couple of users got it working but the throughput wasn't very good.
Draftrabbit
Both routers are lovely, My only issue is that they are somewhat difficult to set up if they don't pick-up the Internet type right away.
Quote from: karlos103
Just for the sake of correctness, AVM say 'VDSL' in their spec. but I can assure you all this is VDSL2.
Call me 'w23'
karlos103
looks like bit more digging required lol
cheers all
karlos103
Just got me an Asus DSL-N66U modem/router from PC World to replace my homehub 5 which keeps disconnecting due to a firmware issue. (got it Monday )
Well got it onto net with in few minutes no problem .
Issue is - when on 5ghz wifi im getting around 10mb lower speeds compared to lan connection ....tried every setting you can think of but still same , moved router to another position and tried different firmware ...stil no different .
Says connect at 300mps and testing next to router .
On 2.4ghz on same pc or even a different pc im getting 20mb...tried all settings again still no different and connected at 300mbps .
Hardwired into lan im get a constant 52mb download ...2.4ghz im getting around 32mb download , 5ghz around 42mb ....upload speed on both is same as lan connection .
Soon as go back to my BT Homehub 5 ...wifi speeds are fine , no different to lan connecting when next to router !!
Been back to PC world and got full refund !!!
Karl
