Asus DSL N66U Wireless Router setup
- Re: Asus DSL N66U Wireless Router setup
21-11-2013 11:41 AM
I have recently bought an Asus ‘DSL N66U’. It has inputs for both a fibre modem and a DSL input for ADSL type services. My problem is that it refuses to connect to my current plusnet service (ADSL). I spent well over an hour on the phone to plusnet support on Saturday and, although the guy I got was very helpful, between us we got nowhere. But we have tried everything obvious.
Can anyone assist with this? If someone has the same router and can tell me what the setting should be it will help. There are so many variations to choose from that I could spend months trying them all. I can’t even confirm that the router works with PLusnet.
21-11-2013 11:53 AM
I don't have one but I'll try to help if possible.
Is the DSL light on ?
I've downloaded the manual but it's not very good. Some routers with both DSL and WAN ports seem not to autodetect the connection very well.
My guess is that you may need to configure the Advanced WAN settings to force use of the DSL port
21-11-2013 1:13 PM
21-11-2013 1:59 PM
21-11-2013 6:33 PM
21-11-2013 6:49 PM
21-11-2013 9:05 PM
Thanks for your help, it was much appreciated.
22-11-2013 8:11 AM
24-11-2013 9:36 PM
Cheers
2011-12-20 11:20:50 [Emergency] WAN Connection: Fail to connect with some issues.
2011-12-20 11:20:50 [Informational] WEB: Configuration changed
2011-12-20 11:20:55 [Emergency] WAN Connection: Ethernet link up.
2011-12-20 11:21:30 [Emergency] WAN Connection: Ethernet link down.
2011-12-20 11:21:35 [Emergency] WAN Connection: Ethernet link up.
2011-12-20 11:21:43 [Emergency] WAN Connection: Fail to connect with some issues.
2011-12-20 11:21:48 [Emergency] WAN Connection: Ethernet link up.
2011-12-20 11:22:13 [Emergency] WAN Connection: Ethernet link up.
2011-12-20 11:22:49 [Warning] kernel: ANNEXAIJLM^M
2011-12-20 11:22:49 [Informational] WEB: Configuration changed
2011-12-20 11:22:50 [Emergency] WAN Connection: Ethernet link down.
2011-12-20 11:22:55 [Emergency] WAN Connection: Ethernet link up.
2011-12-20 11:22:56 [Emergency] WAN Connection: Fail to connect with some issues.
2011-12-20 11:23:21 [Emergency] WAN Connection: Ethernet link up.
25-11-2013 12:12 PM
It seems to be detecting a connection on the ethernet WAN port. You shouldn't have anything plugged into that port, I thought you had an ADSL connection ?
Quote 2011-12-20 11:20:55 [Emergency] WAN Connection: Ethernet link up.
25-11-2013 12:56 PM
26-11-2013 5:10 PM
Does any techie have an idea of how PlusNet present there service that may be effecting the routers ability to 'see' it when first plugged in'
26-11-2013 6:52 PM
I wonder if you are on an ADSL1 connection ? the others will be ADSL2. Normally routers will default to multi mode and sync with whatever the exchange is set to, maybe the Asus is set to ADSL2 only ?
Can You post the stats from your existing router.
02-03-2014 6:42 PM
Hi could someone please let me know if i have correct settings am on plusnet fibre . Everything seems to be working ok just wanting to double check tyvm
01-10-2014 4:49 PM
