Asus DSL-N55u and ICMP Ping
- Asus DSL-N55u and ICMP Ping
26-04-2014 2:53 PM
Im trying to get the router I have just put in working with the a Broardband quality meter that you can use in one of the forums (When its working it gives a great view of the line and connection quality) But for some reason its all blocked out in red which means apparently that there is a problem with the ICMP Ping not getting through and I just wondered if anyone knew where to change it in the routers GUI please? Thanks
regs Osh
Re: Asus DSL-N55u and ICMP Ping
26-04-2014 4:39 PM
Under Firewall > Respond Ping Request from WAN
I would update your router to the latest firmware which came out last week (there are a lot of security fixes).
27-04-2014 1:05 AM
I did the upgrade a couple of days ago S8o should be OK but looks like I have got some settings wrong as it keeps dropping out a couple of times a day?
Regs Osh
27-04-2014 8:55 AM
Broadband connection settings
and
Your Connection Details
Try connecting your modem to the Test Socket
Try following the advice in Connection Troubleshooting - standard (ADSL) broadband,
and if that fails then use the Broadband Troubleshooter to get Plusnet to check your connection.
27-04-2014 2:26 PM
Iv looked and as well as PPP0E instead of PPPoA Its also set as LLC instead of VC-Mux. So think I will have to have another go at setting the Asus DSL-N55u up from start Just because that before when I first set it up it did so automatically. Hence why its set to the PPPoE and LLC I think
And I run the Modem/Router from the test socket as I have always found this the best way..
But when all said and done its going to be down to my setting in the router thats the problem I think anyway.
Regs
27-04-2014 3:09 PM
Do you have any devices set to DMZ?
27-04-2014 10:33 PM
Here is small dump of the log of what has been happening quite a lot.And where and when the modem has been dropping connection.
Apr 26 19:46:04 smbd[1661]: [2014/04/26 19:46:04, 0] smbd/sesssetup.c:reply_sesssetup_and_X(1265)
Apr 26 19:46:04 smbd[1661]: reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was not negoitiated.
Apr 26 20:45:23 pppd[326]: Serial link appears to be disconnected.
Apr 26 20:45:28 WAN Connection: Fail to connect with some issues.
Apr 26 20:45:28 stop_nat_rules: apply the redirect_rules!
Apr 26 20:45:28 WAN Connection: Ethernet link down.
Apr 26 20:45:29 pppd[326]: Connection terminated.
Apr 26 20:45:30 pppd[326]: Modem hangup
Apr 26 20:46:04 miniupnpd[1446]: ioctl(s, SIOCGIFADDR, ...): No such device
Apr 26 20:46:30 pppd[326]: Timeout waiting for PADS packets
Apr 26 20:47:05 pppd[326]: Timeout waiting for PADO packets
Apr 26 20:47:20 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
Apr 26 20:47:20 pppd[326]: Connect: ppp0 <--> eth2.1.1
Apr 26 20:47:50 pppd[326]: LCP: timeout sending Config-Requests
Apr 26 20:47:50 pppd[326]: Connection terminated.
Apr 26 20:47:50 pppd[326]: Modem hangup
Apr 26 20:48:35 pppd[326]: Timeout waiting for PADO packets
Apr 26 20:49:10 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
Apr 26 20:49:10 pppd[326]: Connect: ppp0 <--> eth2.1.1
Apr 26 20:49:11 pppd[326]: CHAP authentication succeeded
Apr 26 20:49:11 pppd[326]: peer from calling number A0:F3:E4:78:A7:77 authorized
Apr 26 20:49:11 pppd[326]: local IP address 84.92.13.45
Apr 26 20:49:11 pppd[326]: remote IP address 195.166.128.190
Apr 26 20:49:11 pppd[326]: primary DNS address 212.159.6.10
Apr 26 20:49:11 pppd[326]: secondary DNS address 212.159.6.9
Apr 26 20:49:11 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
Apr 26 20:49:11 rc_service: ip-up 1682:notify_rc stop_upnp
Apr 26 20:49:11 miniupnpd[1446]: received signal 15, good-bye
Apr 26 20:49:11 rc_service: ip-up 1682:notify_rc start_upnp
Apr 26 20:49:11 miniupnpd[1711]: HTTP listening on port 59309
Apr 26 20:49:11 miniupnpd[1711]: Listening for NAT-PMP traffic on port 5351
Apr 26 20:49:16 WAN Connection: WAN was restored.
Apr 26 21:21:54 rc_service: httpd 295:notify_rc restart_firewall
Apr 26 21:21:54 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
Apr 26 21:26:51 rc_service: httpd 295:notify_rc restart_firewall
Apr 26 21:26:51 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
Apr 26 21:26:52 kernel: DROP <4>DROP IN=ppp0 OUT= MAC= <1>SRC=80.249.99.164 DST=84.92.13.45 <1>LEN=28 TOS=0x00 PREC=0xA0 TTL=59 ID=47767 PROTO=ICMP TYPE=8 CODE=0 ID=32854 SEQ=58295
As for DMZ Its not even enabled?
Thanks again All the best..
Regs Osh
04-05-2014 5:51 PM
As now its done it again with a different cause?
Log reads..
May 1 04:12:32 pppd[326]: Serial link appears to be disconnected.
May 1 04:12:35 WAN Connection: Fail to connect with some issues.
May 1 04:12:35 stop_nat_rules: apply the redirect_rules!
May 1 04:12:36 WAN Connection: Ethernet link down.
May 1 04:12:38 pppd[326]: Connection terminated.
May 1 04:12:38 pppd[326]: Modem hangup
May 1 04:12:48 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
May 1 04:12:48 pppd[326]: Connect: ppp0 <--> eth2.1.1
May 1 04:12:56 miniupnpd[2633]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
May 1 04:12:58 miniupnpd[2633]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
May 1 04:13:30 pppd[326]: Connection terminated.
May 1 04:13:30 pppd[326]: Modem hangup
May 1 04:13:40 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
May 1 04:13:40 pppd[326]: Connect: ppp0 <--> eth2.1.1
May 1 04:13:46 pppd[326]: CHAP authentication succeeded
May 1 04:13:46 pppd[326]: peer from calling number A0:F3:E4:78:A7:77 authorized
May 1 04:14:02 pppd[326]: local IP address 84.92.13.45
May 1 04:14:02 pppd[326]: remote IP address 195.166.128.182
May 1 04:14:02 pppd[326]: primary DNS address 212.159.6.9
May 1 04:14:02 pppd[326]: secondary DNS address 212.159.6.10
May 1 04:14:02 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
May 1 04:14:02 rc_service: ip-up 2686:notify_rc stop_upnp
May 1 04:14:02 miniupnpd[2633]: received signal 15, good-bye
May 1 04:14:02 rc_service: ip-up 2686:notify_rc start_upnp
May 1 04:14:02 miniupnpd[2715]: HTTP listening on port 33067
May 1 04:14:02 miniupnpd[2715]: Listening for NAT-PMP traffic on port 5351
May 1 04:14:06 WAN Connection: WAN was restored.
May 1 08:46:58 rc_service: httpd 295:notify_rc restart_wireless
May 1 08:47:00 kernel: RtmpOSNetDevDetach(): RtmpOSNetDeviceDetach(), dev->name=rai0!
May 1 08:47:00 kernel: RtmpOSNetDevDetach(): RtmpOSNetDeviceDetach(), dev->name=ra0!
May 1 08:47:02 kernel: === pAd = c0056000, size = 851864 ===
May 1 08:47:02 kernel: <-- RTMPAllocAdapterBlock, Status=0
May 1 08:47:02 kernel: register rt2860
May 1 08:47:02 kernel: === pAd = c0151000, size = 725984 ===
May 1 08:47:02 kernel: <-- RTMPAllocTxRxRingMemory, Status=0
May 1 08:47:02 kernel: pAd->CSRBaseAddress =0xc0140000, csr_addr=0xc0140000!
May 1 08:47:03 kernel: RX DESC a6179000 size = 2048
May 1 08:47:04 kernel: RtmpChipOpsEepromHook::e2p_type=0, inf_Type=5
May 1 08:47:04 kernel: NVM is FLASH mode
May 1 08:47:04 kernel: 1. Phy Mode = 9
May 1 08:47:04 kernel: 2. Phy Mode = 9
May 1 08:47:04 kernel: 3. Phy Mode = 9
May 1 08:47:04 kernel: ^[[mAntCfgInit: primary/secondary ant 0/1
May 1 08:47:04 kernel: ^[[mRTMPSetPhyMode: channel is out of range, use first channel=0
May 1 08:47:04 kernel: MCS Set = ff ff 00 00 01
May 1 08:47:04 kernel: SYNC - BBP R4 to 20MHz.l
May 1 08:47:07 kernel: ch1 bssid=9c:97:26:76:53:1f
May 1 08:47:07 kernel: ch1 bssid=7c:4c:a5:c0:5b:d9
May 1 08:47:07 kernel: ch1 bssid=6a:96:7b:a8:37:37
May 1 08:47:07 kernel: ch6 bssid=94:44:52:0e:73:c3
May 1 08:47:07 kernel: ch8 bssid=74:44:01:5c:ae:c0
May 1 08:47:07 kernel: ch8 bssid=28:3c:e4:09:61:14
May 1 08:47:07 kernel: ch11 bssid=18:62:2c:18:1c:2b
May 1 08:47:07 kernel: ch11 bssid=00:01:3b:b3:63:da
May 1 08:47:07 kernel: ch11 bssid=02:01:3b:b3:63:da
May 1 08:47:07 kernel: ch11 bssid=a0:21:b7:d0:cc:28
May 1 08:47:07 kernel: ch11 bssid=18:62:2c:18:1c:28
May 1 08:47:07 kernel: =====================================================
May 1 08:47:07 kernel: Channel 1 : Dirty = 210, False CCA = 20, Busy Time = 5303, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 2 : Dirty = 116, False CCA = 51, Busy Time = 6251, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 3 : Dirty = 108, False CCA = 36, Busy Time = 5257, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 4 : Dirty = 140, False CCA = 7, Busy Time = 552, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 5 : Dirty = 140, False CCA = 38, Busy Time = 4595, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 6 : Dirty = 126, False CCA = 117, Busy Time = 7428, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 7 : Dirty = 196, False CCA = 36, Busy Time = 4556, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 8 : Dirty = 288, False CCA = 408, Busy Time = 18929, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 9 : Dirty = 228, False CCA = 42, Busy Time = 7034, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 10 : Dirty = 236, False CCA = 165, Busy Time = 4275, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 11 : Dirty = 398, False CCA = 260, Busy Time = 13085, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 12 : Dirty = 200, False CCA = 17, Busy Time = 12374, Skip Channel = FALSE
May 1 08:47:07 kernel: Channel 13 : Dirty = 140, False CCA = 127, Busy Time = 5678, Skip Channel = FALSE
May 1 08:47:07 kernel: Rule 1 CCA value : Min Dirtiness (Include extension channel) ==> Select Channel 2
May 1 08:47:07 kernel: Min Dirty = 242
May 1 08:47:07 kernel: ExChannel = 6 , 0
May 1 08:47:07 kernel: BW = 40
May 1 08:47:07 kernel: SYNC - BBP R4 to 20MHz.l
May 1 08:47:08 kernel: SYNC - BBP R4 to 20MHz.l
May 1 08:47:09 kernel: SYNC - BBP R4 to 20MHz.l
May 1 08:47:10 kernel: Main bssid = d8:50:e6:b2:09:e0
May 1 08:47:10 kernel: <==== rt28xx_init, Status=0
May 1 08:47:10 kernel: 0x1300 = 00064380
May 1 08:47:10 kernel: RX DESC a6f5e000 size = 2048
May 1 08:47:10 kernel: <-- RTMPAllocTxRxRingMemory, Status=0
May 1 08:47:10 kernel: 1. Phy Mode = 8
May 1 08:47:10 kernel: 2. Phy Mode = 8
May 1 08:47:10 kernel: 3. Phy Mode = 8
May 1 08:47:10 kernel: ^[[mAntCfgInit: primary/secondary ant 0/1
May 1 08:47:10 kernel: ^[[mRTMPSetPhyMode: channel is out of range, use first channel=0
May 1 08:47:10 kernel: MCS Set = ff ff ff 00 01
May 1 08:47:10 kernel: SYNC - BBP R4 to 20MHz.l
May 1 08:47:11 kernel: =====================================================
May 1 08:47:11 kernel: Channel 36 : Dirty = 0, False CCA = 1, Busy Time = 23, Skip Channel = FALSE
May 1 08:47:11 kernel: Channel 40 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
May 1 08:47:11 kernel: Channel 44 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
May 1 08:47:11 kernel: Channel 48 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
May 1 08:47:11 kernel: Rule 1 CCA value : Min Dirtiness (Include extension channel) ==> Select Channel 36
May 1 08:47:11 kernel: Min Dirty = 0
May 1 08:47:11 kernel: ExChannel = 0 , 0
May 1 08:47:11 kernel: BW = 40
May 1 08:47:11 kernel: Main bssid = d8:50:e6:b2:09:e4
May 1 08:47:11 kernel: <==== rt28xx_init, Status=0
May 1 08:47:11 kernel: 0x1300 = 00064380
May 1 08:47:11 kernel: Ebtables v2.0 registered
May 1 17:27:20 miniupnpd[2715]: HTTP Connection from 192.168.1.60 closed unexpectedly
May 2 09:34:12 WAN Connection: Ethernet link down.
May 2 09:34:12 stop_nat_rules: apply the redirect_rules!
May 2 09:34:48 pppd[326]: Serial link appears to be disconnected.
May 2 09:34:54 pppd[326]: Connection terminated.
May 2 09:34:54 pppd[326]: Modem hangup
May 2 09:35:17 miniupnpd[2715]: ioctl(s, SIOCGIFADDR, ...): No such device
May 2 09:35:39 pppd[326]: Timeout waiting for PADO packets
May 2 09:35:45 miniupnpd[2715]: ioctl(s, SIOCGIFADDR, ...): No such device
May 2 09:35:48 miniupnpd[2715]: ioctl(s, SIOCGIFADDR, ...): No such device
May 2 09:36:14 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
May 2 09:36:14 pppd[326]: Connect: ppp0 <--> eth2.1.1
May 2 09:36:15 pppd[326]: CHAP authentication succeeded
May 2 09:36:15 pppd[326]: peer from calling number A0:F3:E4:78:A7:77 authorized
May 2 09:36:15 pppd[326]: local IP address 84.92.13.45
May 2 09:36:15 pppd[326]: remote IP address 195.166.128.228
May 2 09:36:15 pppd[326]: primary DNS address 212.159.6.9
May 2 09:36:15 pppd[326]: secondary DNS address 212.159.6.10
May 2 09:36:16 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
May 2 09:36:16 rc_service: ip-up 2991:notify_rc stop_upnp
May 2 09:36:16 miniupnpd[2715]: received signal 15, good-bye
May 2 09:36:16 rc_service: ip-up 2991:notify_rc start_upnp
May 2 09:36:16 miniupnpd[3020]: HTTP listening on port 55481
May 2 09:36:16 miniupnpd[3020]: Listening for NAT-PMP traffic on port 5351
May 2 09:36:20 WAN Connection: WAN was restored.
May 2 19:51:47 miniupnpd[3020]: HTTP Connection from 192.168.1.60 closed unexpectedly
May 3 07:01:50 pppd[326]: Connection terminated.
May 3 07:01:50 pppd[326]: Modem hangup
May 3 07:01:51 WAN Connection: Fail to connect with some issues.
May 3 07:01:51 stop_nat_rules: apply the redirect_rules!
May 3 07:01:51 WAN Connection: Ethernet link down.
May 3 07:02:00 pppd[326]: Connected to a0:f3:e4:78:a7:77 via interface eth2.1.1
May 3 07:02:00 pppd[326]: Connect: ppp0 <--> eth2.1.1
May 3 07:02:01 pppd[326]: CHAP authentication succeeded
May 3 07:02:01 pppd[326]: peer from calling number A0:F3:E4:78:A7:77 authorized
May 3 07:02:01 pppd[326]: local IP address 84.92.13.45
May 3 07:02:01 pppd[326]: remote IP address 195.166.128.186
May 3 07:02:01 pppd[326]: primary DNS address 212.159.6.9
May 3 07:02:01 pppd[326]: secondary DNS address 212.159.6.10
May 3 07:02:01 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
May 3 07:02:01 rc_service: ip-up 3139:notify_rc stop_upnp
May 3 07:02:01 miniupnpd[3020]: received signal 15, good-bye
May 3 07:02:01 rc_service: ip-up 3139:notify_rc start_upnp
May 3 07:02:01 miniupnpd[3168]: HTTP listening on port 59648
May 3 07:02:01 miniupnpd[3168]: Listening for NAT-PMP traffic on port 5351
May 3 07:02:03 WAN Connection: WAN was restored.
May 4 09:46:03 miniupnpd[3168]: HTTP Connection from 192.168.1.60 closed unexpectedly
I am at a loss as to what is happenng?
Regs Osh..
04-05-2014 6:35 PM
Can you post the modem stats (snr margin/line attenuation etc.)?
04-05-2014 11:42 PM
Here are the stats
Modulation : ADSL2
Annex Mode : Annex A/L
Line State : up
Lan Tx : 72140558
Lan Rx : 50224790
ADSL Tx : 9320235
ADSL Rx : 13093541
CRC Down : 0
CRC Up : 2716
FEC Down : 0
FEC Up : 13686
HEC Down : 10015
HEC Up : 0
SNR Up : 20.5
SNR Down : 7.0
Line Attenuation Up : 32.9
Line Attenuation Down : 57.0
Data Rate Up : 443
Data Rate Down : 4295
05-05-2014 10:32 AM
Are you connected to the master socket?
05-05-2014 12:35 PM
Quote from: AndyH Something isn't right there - your sync rate of 4295 is too high for the line attenuation I think.
Hi Andy
Yes direct into the test socket. Its been at between 3900 and 4460 since Chris reset my SNR a couple of months ago. Till then The fastest I had got for the last few years was around 3000,
Also according to Plusnet the disconnections that the router has shown have not actually come up as disconnections on their end well not all. There have been 12 disconnects in the last 11 days but like I said not all shown Up but the last couple has shown up those are the one in the log that have something to do with the when its on about channels being dirty . (god only knows what that is :LOL).
They also told me to change over PPPoE to PPPoA and LLC to VC-Mux in the WAN settings which I did last night .as is shown here in the log. at 22.45 on the 4th of April
May 4 22:45:48 rc_service: httpd 295:notify_rc restart_dslwan_if 0
May 4 22:45:49 WAN Connection: Fail to connect with some issues.
May 4 22:45:49 stop_nat_rules: apply the redirect_rules!
May 4 22:45:50 stop_wan(): perform DHCP release
May 4 22:45:54 WAN Connection: Ethernet link down.
May 4 22:46:03 kernel: eth2.1.1: Setting MAC address to d8 50 e6 b2 09 e0.
May 4 22:46:03 pppd[3355]: pppd 2.4.5 started by admin, uid 0
May 4 22:46:03 pppd[3355]: Connected to 00:aa:bb:01:23:45 via interface eth2.1.1
May 4 22:46:03 pppd[3355]: Connect: ppp0 <--> eth2.1.1
May 4 22:46:06 pppd[3355]: CHAP authentication succeeded
May 4 22:46:06 pppd[3355]: peer from calling number 00:AA:BB:01:23:45 authorized
May 4 22:46:06 pppd[3355]: local IP address 84.92.13.45
May 4 22:46:06 pppd[3355]: remote IP address 195.166.128.182
May 4 22:46:06 pppd[3355]: primary DNS address 212.159.6.10
May 4 22:46:06 pppd[3355]: secondary DNS address 212.159.6.9
May 4 22:46:07 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
May 4 22:46:07 rc_service: ip-up 3359:notify_rc stop_upnp
May 4 22:46:07 miniupnpd[3168]: received signal 15, good-bye
May 4 22:46:07 rc_service: ip-up 3359:notify_rc start_upnp
May 4 22:46:07 miniupnpd[3388]: HTTP listening on port 42975
May 4 22:46:07 miniupnpd[3388]: Listening for NAT-PMP traffic on port 5351
May 4 22:46:08 WAN Connection: WAN was restored.
May 4 22:46:14 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth2.1.1)!
May 4 22:46:14 zcip client: configured 169.254.97.96
Regs Osh
