Asus DSL N55U & FTTC
- Asus DSL N55U & FTTC
04-06-2014 10:52 PM
Hi
The ASUS DSL N55U (ADSL Modem) can now also do PPPoE via one of the ethernet ports. Am I correct in thinking that this can therefore be used in place of the plusnet supplied router when FTTC finally arrives this summer?
Thanks.
Thanks.
Message 1 of 8
(2,236 Views)
7 REPLIES 7
Re: Asus DSL N55U & FTTC
04-06-2014 11:03 PM
You can. I use the exact same router linked up to the BT modem installed by openreach and its perfect
Message 2 of 8
(1,348 Views)
24-09-2014 1:15 PM
I have the latest Firmware installed. Not having any luck with setting the Ethernet Wan to Lan port 1 and attempting to connect via PPPoE. Any tips please?
Message 3 of 8
(1,348 Views)
24-09-2014 1:39 PM
I've no idea about the ASUS but other routers with the facility to utilise an ethernet port for WAN require either a complete restart or even a factory reset and set-up from scratch when changing between DSL and EWAN operation.
Call me 'w23'
Message 4 of 8
(1,348 Views)
24-09-2014 9:53 PM
Thank you - yep tried that. No luck so far.
Message 5 of 8
(1,348 Views)
24-09-2014 11:19 PM
Can you post screenshots of your settings pages (Scramble your logon details)
Message 6 of 8
(1,348 Views)
25-09-2014 10:39 AM
Hi Tony,
I just removed the log-in details for the benefit of the screenshot
I've tried with and without the service name too - done a couple of hard resets and reflashed the firmware. Also tried manual google DNS's
Thanks for taking a look,
Mark.
Mark.
Message 7 of 8
(1,348 Views)
25-09-2014 12:05 PM
Well, it appears to be sorted. My mistake was to not switch the OpenReach modem off and on when changing the routers over!!!!
Message 8 of 8
(1,348 Views)
