Assigning static ips
- Assigning static ips
22-09-2009 10:53 PM
Please help
I want to assign a static ip for my ps3 so that I can do some port forwarding or maybe even put it into dmz . I've got a dlink2640b router and can't find the settings on the advanced tab.
I know they're there somewhere as I did this before about 18 months ago
Any help would be much appreciated
Message 1 of 3
(795 Views)
2 REPLIES 2
Re: Assigning static ips
22-09-2009 11:35 PM
Looks like that's in the LAN Setup section, in the DHCP server settings bit - though you'll need to know the ps3's MAC address (this should be in the network settings of the ps3 or possibly on a sticker on the bottom).
I found the manual online here: http://laureldsl.net/pdf/D-Link%202640B%20UserManual.pdf (the relevant bit is on page 32/33 I think).
Hope that helps,
Hope that helps,
Message 2 of 3
(371 Views)
23-09-2009 7:53 AM
thanks for your help. I'll take a look at this tonight
Message 3 of 3
(371 Views)
