Ask aquestion
chrisco
Ask aquestion
Is there a problem with the ask a question section, I asked a question yesterday I have had an email with a reply but the link to answer or close the question doesn't seem to be working. Question No. 24874899 could someone at PN check this out for me please.  Huh
1 REPLY
Mand
Re: Ask aquestion
Can you see the reply if you login to the portal? You'd need to click on Help and Support and then My Questions to see the response there.
I'll check out the link issue for you though and raise a problem as necessary.
