Ask aquestion
- Re: Ask aquestion
Ask aquestion
26-04-2008 9:47 PM
Is there a problem with the ask a question section, I asked a question yesterday I have had an email with a reply but the link to answer or close the question doesn't seem to be working. Question No. 24874899 could someone at PN check this out for me please.
Message 1 of 2
(866 Views)
1 REPLY 1
Re: Ask aquestion
27-04-2008 1:01 PM
Can you see the reply if you login to the portal? You'd need to click on Help and Support and then My Questions to see the response there.
I'll check out the link issue for you though and raise a problem as necessary.
Message 2 of 2
(280 Views)
