Are you throttling my parents connection?
CrystalJayme
I did two speed tests today at 1.43pm from http://speedof.me/ and beta.speedtest.net both showing around 12mbps then I at around 6pm I find the connection speed around 2mbps on both sites that I did the other test. This is unacceptable plusnet and you need to get your act together before more of your customers leave. My parents are now thinking about leaving because its obvious that as you are now part of BT you cannot support customers needs any more. We are not happy at all.
CrystalJayme
Re: Are you throttling my parents connection?
Plusnet Staff
Plusnet Staff
Fixes: 159
There can be many reasons for evening slowdowns, but I can assure you on the current products we offer there are no rate limits or throttling. Have your parents reported the issues to us for investigation?
 Chris Parr
 Plusnet Staff
CrystalJayme
Thanks Chris but what is there to investigate when the speeds were fine hitting around 11-13mbps during the day then after 6pm it goes down hill. Its obvious that you cannot support plusnet customers as well as BT subscribers. My parents aren't the only ones who are seeing this. My parents are not receiving the speeds that they were promised and please don't use the sodding excuse of "Well its up to 17mbps" this is not acceptable and its time that you compensate us don't you think?.
CrystalJayme
Screenshot taken tonight via speedtest and sync speed from router TP-LINK VR600 wifi connected at 5hz
This Is Not Acceptable Plusnet
Plusnet Staff
Plusnet Staff
Fixes: 159
To investigate what's causing this, we have more than enough bandwidth across our network so we need to see what's causing the slowdowns.
Do the same slowdowns happen on a wired connection? Is it every night?
 Chris Parr
 Plusnet Staff
