Are you seeing them your end, too?
- Are you seeing them your end, too?
07-10-2013 2:19 PM
I seem to have had a lot of disconnects and resyncs over the last few weeks with S/N margin ranging from just over 6 to under 3 dB.
Sync rate has varied between around 6000 and 5400.
Are you seeing the disconnects at your end as well?
[quote=Current Stats:]Uptime: 0 days, 0:13:51
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 6.002
Data Transferred (Sent/Received) [MB/MB]: 3,04 / 66,22
Output Power (Up/Down) [dBm]: 12,7 / 0,0
Line Attenuation (Up/Down) [dB]: 26,1 / 49,0
SN Margin (Up/Down) [dB]: 6,9 / 6,2
Loss of Link (Remote): -
FEC Errors (Up/Down): 3 / 292
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Forum Moderator and Customer
Message 1 of 3
(595 Views)
2 REPLIES 2
Re: Are you seeing them your end, too?
07-10-2013 5:17 PM
Hi Mav,
The stats you have posted is the same as what is reported when I test your line, I can't see that you SNR has fluctuated though?
These are the disconnections that have happened recently:
<img src="http://community.plus.net/visualradius/generated/image13811619697047.png"/>
Message 2 of 3
(316 Views)
08-10-2013 10:19 AM
Thanks.
I did notice that when the sync had dropped to around 5400 the S/N was under 3 but just over 6 when it resynced yesterday. Currently it's back down to 3.6.
My line is flaky at the best of times.
Message 3 of 3
(316 Views)
