Are you satisfied with the Plusnet router tg582n ?
- Are you satisfied with the Plusnet router tg582n ?
23-04-2013 10:28 PM
Re: Are you satisfied with the Plusnet router tg582n ?
23-04-2013 10:32 PM
23-04-2013 10:38 PM
24-04-2013 1:48 AM
24-04-2013 7:30 AM
Also, seeing as they will charge you an additional £40 if you leave early and don't return it that also implies its not our property either until out of contract
Why they don't just put the early exit charge up to £45.99 is a puzzzling LOL
Anyway. I will no doubt get an Asus N66u as they looks good. Might just hold out (reconfig my old tp-link 8690n for EWAN) until they hit £99 though. £8 to go LOL
24-04-2013 8:40 AM
then each customer would have a choice
24-04-2013 9:24 AM
24-04-2013 9:55 AM
24-04-2013 10:54 AM
Have you tried changing your wireless channel to see if this helps?
24-04-2013 11:00 AM
24-04-2013 11:40 AM
Quote from: chrispurvey @StevieK
I have now tried changing the wireless channel & it has improved the signal strength a little still not quite the 100% from next door but I managed to get it up to between 80 & 85 % now, seems to work better on Manual than Automatic which I did have it set to, now getting connection speeds of 9.6mbs Download & 3.4 Mbs Upload on the Connection speed test on the PS3 , I really should have tried this before so cheers Chris for your help. the only things I can say now is I still find slightly disappointing about this router is that it is supplied for 80-20 FTTC but does not seem to be able to achieve anywhere near these speeds if you connect to it by wireless, im not sure if it has a gigabit port like the BT Homehub 3 seems to have on it, but you would have thought that would have been a preferable thing to have on it as standard so you can take full advantage the superfast Broadband connection I now have
24-04-2013 1:23 PM
24-04-2013 2:42 PM
24-04-2013 3:22 PM
I was about to post a query on here cos ive had a ticket open for 6weeks+ now, frankly replies seem quicker on here than on the ticket !
I think my problems are due to the router, when i found this thread. Ive had issues with gaming (previously posted about), very slow speeds and wifi losing connection, all of which i think are due to the router. So, no not satisfied !
24-04-2013 3:47 PM
