Are we with plusnet yet ?
- Are we with plusnet yet ?
04-10-2011 4:32 PM
Re: Are we with plusnet yet ?
04-10-2011 4:35 PM
I see you have posted via a BT connection.
04-10-2011 4:37 PM
04-10-2011 4:40 PM
Does this mean Plusnet will work with my home Hub?
04-10-2011 4:43 PM
04-10-2011 4:44 PM
I am not sure whether this affects the billing date but certainly until you change it your usage won't be counted by Plusnet
04-10-2011 4:46 PM
dick:quote
04-10-2011 4:48 PM
Quote from: galaxy66 Does this mean Plusnet will work with my home Hub?
If you can change the login details to the settings given here you can use nearly any router.
More information you might need here: http://www.plus.net/support/broadband/help_and_setup/connections_settings.shtml
04-10-2011 4:50 PM
04-10-2011 4:52 PM
04-10-2011 5:00 PM
I was thinking that before you posted as in them days I was getting 10+ disconnections per day.
04-10-2011 9:01 PM
Quote from: Joanne I don't think you get kicked by BT but if your connection drops you won't be able to reconnect with them. Your billing with us started as soon as it was activated, but we won't be able to register any usage until you connect to us.
Hi Joanne, up and running now but not happy with what BT now say is my maximum achievable speed that the line can give since moving over, which is now less than a third of what it was, I will start new thread and ask for advice.
06-10-2011 11:21 AM
06-10-2011 2:28 PM
Quote from: _Adam_Walker_ Have you started a new thread? I'd advise due to the forum rules keeping things to the one thread...
I am not quite sure what you are getting at Adam ??, the other thread is an entirely different issue, this issue has been resolved which is why I stated I would start another thread. what would be the point of discussing different issues in the same thread it would have to have multiple titles
06-10-2011 2:36 PM
