Are these stats normal.
- Are these stats normal.
23-09-2008 11:55 AM
Could someone advise if the stats below are normal and to be expected. Line speed used to sync'd at 8128 now as you can see this is down to half the figure to change is the sync speed the snrs etc are the same as always with the exception of regular made intermitant changes in downstream margin when the street lights come on. Previous download tests used to show download more than my current sync speed.
and
Here are my current line stats and pings:
DSL Status: Up
DSL Modulation Mode: GDMT
DSL Path Mode: FAST
Downstream Rate: 4064 Kbps
Upstream Rate: 448 Kbps
Downstream Margin: 12 db (This can vary between 15 and 2 depending on what time of day it is.)
Upstream Margin: 24 db
Downstream Line Attenuation: 43
Upstream Line Attenuation: 24
Downstream Transmit Power: 0
Upstream Transmit Power: 0
Todays pings.
Here's a Maidenhead test:
London:
Dublin:
Here are some pings:
C:\>ping speedtest
Pinging speedtest[69.17.117.207] with 32 bytes of data:
Reply from 69.17.117.207: bytes=32 time=197ms TTL=50
Reply from 69.17.117.207: bytes=32 time=204ms TTL=50
Reply from 69.17.117.207: bytes=32 time=201ms TTL=50
Ping statistics for 69.17.117.207:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 197ms, Maximum = 204ms, Average = 199ms
C:\>ping the beeb
Pinging beeb [212.58.251.195] with 32 bytes of data:
Reply from 212.58.251.195: bytes=32 time=33ms TTL=120
Reply from 212.58.251.195: bytes=32 time=110ms TTL=120
Reply from 212.58.251.195: bytes=32 time=27ms TTL=120
Reply from 212.58.251.195: bytes=32 time=36ms TTL=120
Ping statistics for 212.58.251.195:
Minimum = 27ms, Maximum = 110ms, Average = 51ms
C:\>ping google
Pinging google [66.102.9.147] with 32 bytes of data:
Reply from 66.102.9.147: bytes=32 time=42ms TTL=245
Reply from 66.102.9.147: bytes=32 time=40ms TTL=245
Reply from 66.102.9.147: bytes=32 time=50ms TTL=245
Reply from 66.102.9.147: bytes=32 time=56ms TTL=245
Ping statistics for 66.102.9.147:
Minimum = 40ms, Maximum = 56ms, Average = 47ms
C:\>ping my isp plusnet
Pinging my isp [212.159.9.2] with 32 bytes of data:
Reply from 212.159.9.2: bytes=32 time=54ms TTL=249
Reply from 212.159.9.2: bytes=32 time=36ms TTL=249
Reply from 212.159.9.2: bytes=32 time=35ms TTL=249
Reply from 212.159.9.2: bytes=32 time=34ms TTL=249
Ping statistics for 212.159.9.2:
Minimum = 34ms, Maximum = 54ms, Average = 39ms
C:\>ping bt
Pinging bt [217.32.165.146] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 217.32.165.146:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
TODAY
London
Maidenhead
Dublin
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Alan>ping www.plus.net
Pinging portal.plus.net [212.159.8.2] with 32 bytes of data:
Reply from 212.159.8.2: bytes=32 time=40ms TTL=249
Reply from 212.159.8.2: bytes=32 time=36ms TTL=249
Reply from 212.159.8.2: bytes=32 time=35ms TTL=249
Ping statistics for 212.159.8.2:
Minimum = 35ms, Maximum = 40ms, Average = 36ms
C:\Users\Alan>ping www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.253.67] with 32 bytes of data:
Reply from 212.58.253.67: bytes=32 time=28ms TTL=120
Ping statistics for 212.58.253.67:
Minimum = 28ms, Maximum = 28ms, Average = 28ms
C:\Users\Alan>ping www.carmylechurch.co.uk
Pinging www.carmylechurch.co.uk [81.169.145.70] with 32 bytes of data:
Reply from 81.169.145.70: bytes=32 time=46ms TTL=246
Reply from 81.169.145.70: bytes=32 time=47ms TTL=246
Ping statistics for 81.169.145.70:
Minimum = 46ms, Maximum = 47ms, Average = 46ms
C:\Users\Alan>ping www.bt.com
Pinging www.bt.com [217.32.165.146] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\Users\Alan>ping www.google.co.uk
Pinging www.l.google.com [66.102.9.99] with 32 bytes of data:
Reply from 66.102.9.99: bytes=32 time=40ms TTL=245
Reply from 66.102.9.99: bytes=32 time=42ms TTL=245
Ping statistics for 66.102.9.99:
Minimum = 40ms, Maximum = 42ms, Average = 41ms
C:\Users\Alan>www.pcworld.co.uk
'www.pcworld.co.uk' is not recognized as an internal or external command,
operable program or batch file.
C:\Users\Alan>ping www.pcworld.co.uk
Pinging www.pcworld.co.uk [195.92.228.186] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 195.92.228.186:
C:\Users\Alan>
I have a adslnation plate fittied with no ring wire. I have good duty cable between socket and router. Can anyone suggest another site i could use to ping and get reliable results.
it's ben suggested I may have an issue with my line but as the conversations are ok with no static I'm not sure what could be done. Can anyone advise?
Regards,
Podman
Message 1 of 2
(1,161 Views)
1 REPLY 1
Re: Are these stats normal.
30-09-2008 3:59 PM
Have you tried the BT speed tester?
http://speedtester.bt.com/
And followed this?
http://community.plus.net/blog/2007/07/02/broadband-speed-faults-how-to-diagnose/
And followed this?
Message 2 of 2
(453 Views)
