Are these reasonable line stats?
- Are these reasonable line stats?
- « Previous
- 1
- 2
- Next »
Re: Are these reasonable line stats?
11-07-2009 9:25 PM
There are a few occassional faint pops (with router not connected)-so do I report a line fault (and follow the advice to make no mention of broadband)?
Message 16 of 20
(262 Views)
11-07-2009 10:15 PM
It is definitely worth a try - but if they are very faint you probably won't get anywhere - but before you do a couple of points -
The test should be with a wired phone not cordless
Have you got an outstanding fault with BT via Plusnet - if you have reporting a voice fault will cancel it.
Message 17 of 20
(262 Views)
13-07-2009 2:45 PM
If there's some noise on the line I'd definitely recommend raising it with your voice supplier.
Message 18 of 20
(262 Views)
13-07-2009 2:53 PM
My ticket (29265416) is currently with BT for further investigation. Had a call from support yesterday-they said not to take any notice of speed tests at the moment, as the issue is mutiple line drops more than anything. I'm waiting to hear what BT response will be.
After all, I'm now connected via the BTE-5 plate, so any internal issues are out of the equation.
Message 19 of 20
(262 Views)
13-07-2009 2:56 PM
Steve,
That's a fault on trhe broadband side of things.
I'd more more inclined to try raising a fault on the voice side of the line first as any issues with your voice line will directly impact your broadband service.
Message 20 of 20
(262 Views)
- « Previous
- 1
- 2
- Next »
