Are there any Spec/ Info for the USB on the TG582n router
- Re: Are there any Spec/ Info for the USB on the TG...
25-02-2014 9:21 AM
No doubt many of you know I now have a USB TG582n router
I am currently NOT using the USB due to the testing I am doing for the issue(s) via my other thread
Is there any official / unofficial documentation for the USB side of the TG582n
1. Can it see more than 1 partition on a external HDD
2. What formats does it support (work best with) NTFS / Fat / Fat32 etc
3. What are the Read / Write speeds
4. Is it only accessible via FTP:IP Address
5. Does it support DragnDrop / CopynPaste etc
6. Does File Sharing have to be turned on on any devices IE:Windows
7. Are there any known Printers that are to be avoided (which does not work with the TG582n)
8. Can I use a USB Hub so when Printer is not in use the External HDD will still be operational
9. Does it support a USB camera for surveillance
If there is anything else I have not asked / overlooked, I will be grateful to see what the TG582n is capable of
Message 1 of 4
(1,206 Views)
3 REPLIES 3
Re: Are there any Spec/ Info for the USB on the TG582n router
25-02-2014 10:36 AM
Message 2 of 4
(533 Views)
25-02-2014 11:17 AM
Cheers pwatson
They have answered a lot more that I originally asked
I guess my next set of questions are related to actual usage (That the manuals fail to tell us)
1. How secure is the FTP option
2. If I allow remote access (for any valid reason) could I potentially see the files stored on the attached USB devices
3. Can I from a client home (for example) send a file print (similar to a fax)
4. What printers works best with both the 8.44.J & 10.2.2.B Firmwares
5. Using a USB hub can I use a printer & USB HDD @ the same time or would have to wait until the others process has finished 1st
6. Is anyone successfully using a WebCam on the TG582n USB & if so was it easy to set up & can it be accessed via FTP or other means
7. What devices are you using via a hub
8. What HUB are you using Is it a Powered HUB or not
Message 3 of 4
(533 Views)
27-02-2014 9:09 AM
Is there anybody that can answer any of the above from personal / Beta testing experience ?
Message 4 of 4
(533 Views)
