Are modem and router seperate for Plusnet fibre broadband
- Re: Are modem and router seperate for Plusnet fibr...
29-11-2013 1:35 PM
Dear all,
I just ordered Plusnet 76Mbps fibre broadband.
Will I receive a modem and a router separately as two items? Or modem and router are in one box?
I got a Netgear R6300 router at home. Can I use it with the modem supplied by Plusnet on Plusnet fibre broadband?
Thanks.
Thanks.
Message 1 of 7
(2,256 Views)
6 REPLIES 6
Re: Are modem and router seperate for Plusnet fibre broadband
29-11-2013 1:37 PM
BT Openreach will bring a modem when they come to install your fibre.
Plusnet normally post out a router for you a few days before installation date.
Message 2 of 7
(683 Views)
29-11-2013 1:39 PM
Thanks for your quick reply.
What about my last question? Could I use Netgear R6300 with Plusnet fibre broadband?
dick:quote
dick:quote
Message 3 of 7
(683 Views)
29-11-2013 1:41 PM
Sorry, I'm unfamiliar with the R6300.
Maybe someone on the forum who is can offer assistance.
Message 4 of 7
(683 Views)
29-11-2013 2:37 PM
yes it can be used with fibre broadband
as long you know how to log into the router
Message 5 of 7
(683 Views)
29-11-2013 2:49 PM
as david says, It'll work fine.
Quote I got a Netgear R6300 router at home. Can I use it with the modem supplied by Plusnet on Plusnet fibre broadband?
You will need to setup the Internet connection ( page 20 of the manual ) to PPPoE , enter your PlsuNet username & password as defined here http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml . Set the idle time to 0, and use Get IP & DNS from ISP. You should then be good to go...
Message 6 of 7
(683 Views)
29-11-2013 7:37 PM
Great, guys. Thanks a million.
Message 7 of 7
(683 Views)
